WydRyd's Avatar
Cool Replacing Brake Light Switch...
I finally resolved my dodgey brake light switch today
Previously, I had to apply a fair amount of pressure on my brake pedal in order to make the brake lights activate. This was quite stressful in peak hour traffic, especially in wet conditions! I had a couple of near misses, so I finally decided to pull my finger out and do something about it
Anyway, as the pic below shows, the switch to the far back of the Master Cylinder is the brake light switch. The Switch at the front is the Handbrake light switch.
It was a mega PITA to actually get a 22mm spanner to the back switch as there isn't much room there However, I finally got the old one out and quickly had the spare ready to screw in place. Very little brake fluid was lost during the transition
Luckily, I didn't have to replace the Handbrake Switch as I can't imagine doing that with that cylindrical thing right in front of it with those hard lines
Anyway, just thought I'd share
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-25-2005, 01:49 AM
I don't know anything about a hand brake switch, I was told they are both for the brake lights, you get an extra one in case of a failure.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 09-25-2005, 07:55 AM
WydRyd's Avatar
Oh, I'm sure I read somewhere that the second switch is for the handbrake. Could be wrong.
Either way, replacing the rear switch alone fixed my brake light issue
Merv
'89 911 Turbo Cab
Old 09-27-2005, 07:57 PM
The hand brake is a cable and has nothing to do with the hydralic system. You might be using one of the two switches for the brake lights, it would be a good idea to replace the other one also.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 09-29-2005, 04:52 AM
did you have to bleed the brakes ?
Old 05-29-2006, 10:37 AM
rnln's Avatar
None of those are hand brake switch. They are both the pedal brake light witches. Most people said either one good, your brake light is good to go, but for me it's diff. When I replaced one, my brake light still didn't work, soon the second one came in, all my brake light work great.
Fat butt 911, 1987
Old 05-29-2006, 04:20 PM
Make Bruins Great Again
Por_sha911's Avatar
Your system uses two switches as a safety backup. This way if one switch fails you still have brake lights. It is wise to replace both at the same time so that you don't find out that your one good switch failed by having a soccer mom on her cell phone running into the back of your car.
Joe
Old 05-29-2006, 08:35 PM
thanks to everyone who helped me I have new switches on order
rgds
Mike
Old 05-30-2006, 04:33 AM
