911s55,
No clunks (nor snapping) over the pump. I guess because I go very slow over pumps. Or maybe this sond only produced when suspension is complressed on one side and not the other which going over a pump will compress both side equally? If I drive on the road at normal speed or fast on freeway, I will hear this snapping sound even slightly up the grove. The sound will be on either side (left or right) according to the grove. Yes, I did try that turning steering wheel test and sometimes I do hear it, sometimes I don't. Most of the time I don't. Many times testing it this way, I decided the sound won't be produced by turning steering wheel without moving the wheel. 1 question, do you know if the steering coupler is bad, at which point the sound will produce? Suspension compressed, released, or when turning only? Do you know how/where can I check this coupler on an 87?
Fat butt 911, 1987 |
Hope this helps
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I plan on checking the gland nuts and everything else around there, again, this weekends. Do I really have to take the top nut off and pull the strut out to lift the dust cover up enough to view the gland nut?
Why do you call it the "wiper/seal"? Do you mean the nut screwing into the shock (housing) to hold the strut in the shock, or there is anything else I don't know yet?
And yes... you do have to remove the top nut and pull the strut out to lift the dust cover up enough to view the gland nut. Doing this will not affect your alignment.
... just the same as replacing the strut then. Why not pull the strut off to know what I am having. Thanks Nine9six
You may want to check the condition of the "I" shaped cross-member that carries the steering rack - mine had a fracture in it that made a sound very similar to your description.
Jerry M '78 SC |
Jerry,
will do. thanks. Maybe I ask where proximately your fracture located?
Good luck, Jerry M '78 SC |
I had similar crack but only on the thin/small piece (aluminum) to block the adjuster bolt, not accross the bar. I had it welded already. But I will check the whole bar again.
Thanks.
