GrantG's Avatar
Separating Upper Valve Covers from heads?
Hi - first time valve adjust here and I have removed all the nuts (assuming there are only 6 on each side) from the upper valve cover and the thing feels really bonded on. How can I remove it without damaging any metal surfaces? I'm tempted to shove a screwdriver or scraper in there, but don't want to do any harm. Any suggestions?
Thanks!
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 05-21-2006, 06:41 AM
Try sticking your finger inside the hole for the spark plug and pull up. P/O may have used some sort of sealant.
Good luck,
Ben
1986 3.2 Carrera
Old 05-21-2006, 07:46 AM
GrantG's Avatar
Good luck,
Ben
Yep, I tried that but no real progress. Is it easy to do damage with a spackle applicator/scraper, do you think?
Old 05-21-2006, 07:52 AM
Paper Member
If you do it, try to stay on the cover side of the gasket. It'll be much easier to repair any damage to the cover than to the cam towers. That said I'd still try to avoid prying. That's soft metal. Maybe tapping on it for a little will free it up.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 05-21-2006, 08:11 AM
Scott R's Avatar
The first time I had to remove mine they were stuck just like you describe. I used a rubber mallet and smacked the covers a few times and the loosened up.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-21-2006, 08:21 AM
GrantG's Avatar
Thanks guys!
Old 05-21-2006, 08:22 AM
Somatic Negative Optimist
Gunter's Avatar
Try a dull dinner-knife with a round edge, not a scraper.
Or make up a hooking devise for the plug-holes and connect it to a bar, then pull up.
Clean the covers and check them for straightness:
On a plate-glass, put some very fine emery and move the covers over the sandpaper/glass.
When installing the new gaskets, cover them on both sides with anti-seize lube so they won't stick the next time.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-21-2006, 08:23 AM
