Heel toe (today's potentially dumb question)
New 88 Carrera owner here. I cannot, for the life of me, get my right foot on the gas pedal to assist with a proper heel toe. I am not new to the track, or performance driving, but this is really becoming a pain. What have people done? Raised the gas pedal? Aftermarket pedals? Is it just me? Any thoughts are much appreciated.
Ben
Ben 1988 Carrera |
When you get on track and get deeper into the pedal travel it'll be easier. You can also lower the break pedal - but not too much or you'll leave yourself without enough travel for heavy braking.
Some add a "winged" pedal.
'83 SC |
I bought an aftermarket gas pedal and raised it quite a bit.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Here's what I did yesterday on my 964. Not sure if the pedals are the same. Works great but I may fine tune it a bit.
http://forums.rennlist.com/rennforums/showthread.php?t=274254
1987 951 Sunroof Delete |
Left Foot Braking
Ben, I will give you the poor man's solution. Buy a new stock plastic pedal, cut the bottom hinge off, screw it on top of the existing pedal (I moved mine about 1/4" to the left). It has worked great, without having to lower the brake pedal.
rickdm
rickdm '87 Carrera '91 Miata '78 SC (ex) |
I don't know anyone can but on this P car, I just can't heel toe at all. It is impossible with the pedals setup, for me.
Fat butt 911, 1987 |
Adjustable gas pedal from Rennline. Raise it up about 2", and you can blip the throttle with your heel like Michael Schumacher.
My friend, who is more courageous, cut his throttle pushrod in half and added an adjustable turnbuckle thing. Accomplished the same as mine. |
Ben 1988 Carrera |
Ben,
I just took a picture for you about 5 mins. ago of the throttle pedal. Sorry, didn't have time to vacuum the car or clean the pedals and stuff. And I KNOW Schuey uses left foot braking, and the last F1 driver to use heel and toe was Michele Alboretto (may he rest in peace). I'm just saying the feel of the Rennline pedal is really sportscar-ish.
Ben 1988 Carrera |
UFLYICU
Don't use your heel. Use the right half of your right foot, with the left half still on the brake. Also, you can raise the gas pedal about 1/2" with the adjustment in the rod that connects it to the linkage behind the floorboard.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
I had the same problem. It does get much better at the track, but here's what I did. I bought the rennline race pedals (not the big throttle pedal). The pedals are bigger than stock and the throttle pedal has a flange on the left side. The combination of the flange on the throttle pedal and larger brake pedal makes a ton of difference. In addition, I raised the height of the throttle pedal. It's very easy to to do. Just remove the bolts at the bottom of the throttle pedal and then remove the shaft from the ball socket. Pull the pedal out and you'll see two nuts that adjust the height. I put mine in a vice because they were pretty fused.
Sean
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
Administrator
The stock pedals are great for heel-and-toe-ing -- but a lot of guys don't really use their heels or their toes. They use the ball of their braking foot and roll it to the right for the blip.
The gas pedal is adjustable -- but you want to adjust it for track braking, not street braking. If you click on the 'lets go out for a lap' link in my signature, you can see some heel-and-toeing on a 911.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Nice, Jack!!!!
Southern Class & Sass
I have really skinny feet. Yet I can still heel-toe with the stock pedals. I just have to literally use my heel on the gas, and toes on the brake. After about a dozen track events I fabed the pedal below for less than ten dollars.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Bill 87 911 Targa 06 Toyota Sequoia |
I think it was mentioned in the article linked to above, but the easiest thing I found to do (in addition to adjusting the brake pedal height) was to shim the right side of the gas pedal mount with a few washers. This angles the gas pedal over to the left, closer to the brake pedal. Now that's a 10 cent solution that works well, too!
99 996 C2 Black, MY02 wheels, Aerokit Way too much fun! |
Jack that looks like a great video. I tried to watch it on my dial-up, old, and slow computer. But, I'm going to have to find someone w/ a faster computer to watch it. Looks like fun. Thanks, it also looks very instructional. My cabriolet is in the shop getting the top fixed and I have a DAS roll bar on order from a fellow Pelican and will install it sometime this summer w/ a camera mount being purchased sometime in the near future. All I need to do is watch the video a few times and get the car to a track and get some instructions.
Gary
1985 911 Carerra Cab 3.6l 1998 Dodge Ram 2004 Toyota Tundra Quad Cab |
Chad
