New Hi-Torque Starter-can't get used to the noise...
I put a new starter in yesterday as my old one gave up on me. It's a hi-torque starter, and it sounds a whole lot different than stock. It sounds to me like a 70's Toyota Corolla or something-a real "lightweight" sound.
But, the new one weighs 7 1/4 lbs less than the old!! Lightweight goodness. |
How'd that starter installation go with the new lift? :)
Brian |
Brian: It was awesome! I did the starter, installed new Bilstein Sports up front, new front pads and a brake flush in about 3 hours. I'm with the "what ever did I do without it" crowd now for sure.
Re: New Hi-Torque Starter-can't get used to the noise...
Colin Chapman You've taken another step! |
I think of Colin Chapman every time I find the opportunity to take some weight off!
I love the sound of those high torque starters, reminds me of an old big block Mopar motor.
I agree that the starter sounds wimpy, but it all evens out (and then some) when my motor roars to life.
Efhughes, could you post the actual weight of your original starter?
Who supplied you the light one? I was visiting my wifes family over the weekend and a nephew was showing me his lightweight starter for his economy Camaro drag car. Very unique and compact as it used a planetary gearset so the motor remains in-line with the nose gear. Whole unit might have been 3" in diameter. This got me thinking... Jim |
It's definitely smaller in diameter, and makes it pretty easy to install. The only change required to the stock setup, was putting a spade connector on the small yellow wire from the ignition. The big cables bolted right on. |
I bought one from our host, it was an easy dropin, love the sound, it's def a lot lighter compared to the old Bosch unit.
ianc |
My light weight starter doesn't make a significantly different noise from the stock unit. Make sure you installed it correctly!
George |
rumours???is it true
I have a hi-torque starter on my 2.9 twinplug. I really like the weight savings and the sound.
A friend told my the the hi-torque is actually too powerful. It can cause damage to your "pinion"? ( I think that what he said) The force the starter gives off is not meant for our cars...It spins too hard, too fast. Has any one else heard that?? |
I guess i should've clarified- I don't dislike, it just sounds like I'm starting a different car. |
Mopar.... or even Toyota...yeppers.... triple-reduction gear set.... a very unique noise.....
So what ??.... Wil |
Not meant in any adversarial way...just asking......
it indeed is a different sound to get used to..... Wil |
Ed, now you need to redo the corner balancing on your car.
Hey Wil, no sweat.
Neil-don't laugh, but I just dropped it off for 4 wheel align/balance....but, not because of the weight change. |
| All times are GMT -8. The time now is 04:28 AM. |
