efhughes3's Avatar
New Hi-Torque Starter-can't get used to the noise...
I put a new starter in yesterday as my old one gave up on me. It's a hi-torque starter, and it sounds a whole lot different than stock. It sounds to me like a 70's Toyota Corolla or something-a real "lightweight" sound.
But, the new one weighs 7 1/4 lbs less than the old!! Lightweight goodness.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 05-22-2006, 01:47 PM
How'd that starter installation go with the new lift?
Brian
Old 05-22-2006, 01:49 PM
efhughes3's Avatar
Brian: It was awesome! I did the starter, installed new Bilstein Sports up front, new front pads and a brake flush in about 3 hours. I'm with the "what ever did I do without it" crowd now for sure.
Ed Hughes
2015 981 Cayman GTS
Old 05-22-2006, 01:57 PM
Autodidactic user
David E. Clark's Avatar
Re: New Hi-Torque Starter-can't get used to the noise...
Originally posted by efhughes3
... the new one weighs 7 1/4 lbs less than the old!! Lightweight goodness.
"To build the perfect sports car ... Simplify and add lightness"
Colin Chapman
You've taken another step!
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 05-22-2006, 02:00 PM
efhughes3's Avatar
I think of Colin Chapman every time I find the opportunity to take some weight off!
Ed Hughes
2015 981 Cayman GTS
Old 05-22-2006, 05:46 PM
makaio's Avatar
I love the sound of those high torque starters, reminds me of an old big block Mopar motor.
Old 05-22-2006, 06:37 PM
I agree that the starter sounds wimpy, but it all evens out (and then some) when my motor roars to life.
Old 05-22-2006, 06:44 PM
efhughes3's Avatar
Agreed! Plus, I'm all set for when I build my 3.4L high(er) compression twin plug motor.
Ed Hughes
2015 981 Cayman GTS
Old 05-22-2006, 07:00 PM
7.0:1 > 11.3:1 > 7.0:1
Efhughes, could you post the actual weight of your original starter?
Who supplied you the light one?
I was visiting my wifes family over the weekend and a nephew was showing me his lightweight starter for his economy Camaro drag car. Very unique and compact as it used a planetary gearset so the motor remains in-line with the nose gear. Whole unit might have been 3" in diameter.
This got me thinking...
Jim
Old 05-22-2006, 07:04 PM
efhughes3's Avatar
Jim
15lbs 4oz, the new one is 8lbs on the nose. I bought it locally @ Zim's late Friday afternoon, as I had to get it in this weekend, otherwise I would've looked @ Pelican. I'd think they carry these also.
It's definitely smaller in diameter, and makes it pretty easy to install. The only change required to the stock setup, was putting a spade connector on the small yellow wire from the ignition. The big cables bolted right on.
Ed Hughes
2015 981 Cayman GTS
Old 05-22-2006, 07:08 PM
Banned
diabolos88's Avatar
I bought one from our host, it was an easy dropin, love the sound, it's def a lot lighter compared to the old Bosch unit.
Old 05-22-2006, 08:52 PM
ianc's Avatar
Something just doesn't add up here.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 05-22-2006, 09:32 PM
Now in 993 land ...
aigel's Avatar
My light weight starter doesn't make a significantly different noise from the stock unit. Make sure you installed it correctly!
George
81 SC (sold)
Old 05-22-2006, 11:17 PM
rumours???is it true
I have a hi-torque starter on my 2.9 twinplug. I really like the weight savings and the sound.
A friend told my the the hi-torque is actually too powerful. It can cause damage to your "pinion"? ( I think that what he said) The force the starter gives off is not meant for our cars...It spins too hard, too fast.
Has any one else heard that??
Ray Crawford
1972 911 S Targa
1973 E Flairs n Chairs
Old 05-23-2006, 06:08 AM
efhughes3's Avatar
George
There's definitely a different sound, its in correvtly.
I guess i should've clarified- I don't dislike, it just sounds like I'm starting a different car.
Ed Hughes
2015 981 Cayman GTS
Old 05-23-2006, 06:31 AM
Mopar.... or even Toyota...yeppers.... triple-reduction gear set.... a very unique noise.....
So what ??....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-23-2006, 07:22 AM
efhughes3's Avatar
So what ??....
Wil
So what? So as I said above it is like starting a different car. After a few years of hearing the old starter, it's funny how you get used to something...
Ed Hughes
2015 981 Cayman GTS
Old 05-23-2006, 07:55 AM
Not meant in any adversarial way...just asking......
it indeed is a different sound to get used to.....
Wil
Wil Ferch
Old 05-23-2006, 08:04 AM
Ed, now you need to redo the corner balancing on your car.
Neil
'73 911S targa
Old 05-23-2006, 08:10 AM
efhughes3's Avatar
Hey Wil, no sweat.
Neil-don't laugh, but I just dropped it off for 4 wheel align/balance....but, not because of the weight change.
Ed Hughes
2015 981 Cayman GTS
Old 05-23-2006, 10:43 AM
