-   -   Remove Differential while in Car? (http://forums.pelicanparts.com/porsche-911-technical-forum/284400-remove-differential-while-car.html)
randywebb 05-23-2006 02:22 PM
I'm going to try and remove the differential* with the transmission still in the car.
Who has done this and what do I need to watch out for?
For example, will I be able to get the differential out with the heat exchanger there (it's an SSI)? Or am I going to have to remove the heat exchanger too?
Thanks!
* It's a 1971 type 911 transmission and I need to do the simplified differential fix before it blows itself up.
Rot 911 05-23-2006 02:29 PM
Randy, I have to ask why? I can't see you saving any time doing it this way and it seems it would be a lot easier to work on the tranny with it sitting on your workbench then under the car.
randywebb 05-23-2006 02:49 PM
it's a hell of a lot easier if I don't have to pull the entire engine & trans.
bigchillcar 05-23-2006 04:05 PM
we seem to have reached a difference of opinion..what they call an 'impasse'..two immovable schools of thought, passing like great ships in the night.. ;)
john walker's workshop 05-23-2006 05:10 PM
easy. axles disconnected from flanges and tied out of the way, flanges off, side cover off, and watch your feet.
randywebb 05-23-2006 05:22 PM
Thanks, John. I don't have access to a lift anymore so I'll be in a bench-press position...
RarlyL8 05-23-2006 07:58 PM
If I can do it anybody can.
http://forums.pelicanparts.com/uploa...1148439501.jpg
