randywebb's Avatar
Remove Differential while in Car?
I'm going to try and remove the differential* with the transmission still in the car.
Who has done this and what do I need to watch out for?
For example, will I be able to get the differential out with the heat exchanger there (it's an SSI)? Or am I going to have to remove the heat exchanger too?
Thanks!
* It's a 1971 type 911 transmission and I need to do the simplified differential fix before it blows itself up.
Old 05-23-2006, 02:22 PM
Friend of Warren
Randy, I have to ask why? I can't see you saving any time doing it this way and it seems it would be a lot easier to work on the tranny with it sitting on your workbench then under the car.
Kurt V
Old 05-23-2006, 02:29 PM
randywebb's Avatar
it's a hell of a lot easier if I don't have to pull the entire engine & trans.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-23-2006, 02:49 PM
bigchillcar's Avatar
we seem to have reached a difference of opinion..what they call an 'impasse'..two immovable schools of thought, passing like great ships in the night..
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-23-2006, 04:05 PM
easy. axles disconnected from flanges and tied out of the way, flanges off, side cover off, and watch your feet.
206 637 4071
Old 05-23-2006, 05:10 PM
randywebb's Avatar
Thanks, John. I don't have access to a lift anymore so I'll be in a bench-press position...
Old 05-23-2006, 05:22 PM
Crotchety Old Bastard
RarlyL8's Avatar
If I can do it anybody can.
Old 05-23-2006, 07:58 PM
