Monkey Wrench
What do I need to upgrade to power boosted brakes?
I have a 1975 911 and would like to upgrade to power boosted brakes like in the mid-80s Carreras.
What parts do I need? I'm sure it more that just the brake booster thing (excuse the non-technical term) in the front trunk. Do I need a new pedal cluster? Lines? Thanks! |
Booster, sheet metal from mounting area of boosted car, actuating arm from brade pedal to booster, not sure if you can mod an existing pedal cluster or need one from a boosted car, lines, master cylinder, little bits
74 911s neverending story. two feet and a jetta for now. |
1.367m later
I just installed a Boxter Big Brake Kit from TRE in a customers '75 911S. Great Upgrade!! Easy to install and is like the Queen Mary dropping anchor when you need to stop.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Spede
beside the trunk floor sheetmetal- Which a clever metal man can duplicate w/o having to source it. You will also need to reinforce the floor and add reinforcements to the vertical panel in front of the pedal assembly. If you don't you will have a curiously long pedal travel , as the entire brake booster/master cylinder assembly will flex the mounting sheetmetal under hard braking Look at any 77-89 911 in the pedal assembly area and you will see not only the gold zinc plated support, but the additional angled sheet metal supports that are vertically installed in the chassis there so.. a quick list , besides the aforementioned sheet metal work pedal assembly from 77-89 model blank off plate that mounts the pedal assy from the underside (where your existing master mounts) actuation shaft from pedal assy to booster bracket booster support, booster , and master cylinder shorter cardboard trunk cover for underhood fan assy 77-89 brake lines from master cylinder to distribution lines under front end vacuumn line from engine to brake booster
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Monkey Wrench
Wow! Not a small feat!
Do I need to upgrade to a boosted brake system if I am upgrading to 993 calipers all the way around? Or would simply getting a larger master brake cylinder be sufficient? Thanks all!! |
