Normal brake pedal feel???
hello everybody,
i have stock brakes on my 78 930, they're the 4 piston 917 jobbies i believe. i have started to drive the car harder and have noticed the following when braking:
the brake pedal is firm. it does require a little muscle compared to power brakes, but basically-the harder you push, the quicker you stop-which i like, much more mechanical. Now, i've noticed when i really get on the brakes, the pedal feels like it 'hits' or reaches bottom, i'm guestimating 3 inches from top brake pedal position. it just doesn't feel right and as a result, i haven't really pushed them too much/hard. i have a feeling that the fluid has not been changed in a couple of years, due to the car having very little mileage put on it. Is this normal brake pedal travel for p-car---any suggestions welcomed.
best, paul.
84 R5 T2
04 Suby Outback
"it's a mystery, wrapped in a riddle, inside an enigma" Winston Churchill.
Old 05-30-2006, 09:41 AM
Turgid Member
Noney's Avatar
If your brake fluid is a couple of YEARS old, then you are more than ready for some fresh stuff. Some folks, myself included, flush the brakes before every DE event (may be overkill or not, see past discussions....). The point being, p-cars are renowned for their braking ability. If you feel you are having issues with only 3 or so inches of brake travel, then a great place to begin troubleshooting is with some fresh fluid. It's a very easy DIY project, albeit a messy one, but that will at least give you a baseline to work with.
Good luck.
'87 Carrera
"Man who go through airport turnstile sideways going to Bangkok"
Old 05-30-2006, 01:14 PM
Me like track days
Craig 930 RS's Avatar
Don't screw around - use a pressure bleeder with NO fluid in it.
Fill and check reservoir level often and bleed all with ATE or Motul and enjoy.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 05-30-2006, 01:58 PM
Bill Verburg's Avatar
You should have a high hard pedal w/ less travel, sounds like the m/c is stroking out, probably bad seals in there, a new m/c would cure it.
You do have a power booster, it's an 8" vac can w/ ~3:1 boost ratio.
you can check for fluid leaks before buying a new m/c by checking for fluid inside the vacuum can
Bill Verburg
Old 05-30-2006, 02:00 PM
I agree. 3" sounds like a lot of pedal travel. My pedal gets firm after .5" or so and I would probably lock them up if I went another inch.
Old 05-30-2006, 02:06 PM
gilach,
High performance car needs high performance brakes.
You've got 'em, now you need some maintenence.
Change the fluid once a year. Use the good stuff like ATE Blue.
Get some decent pads, Pagid, Ferrado, Hawk.
Others may have more suggestions for pads.
Check and replace your rotors as necessary. Don't run old worn out rotors.
Replace the brake lines if they are original.
If you still have issues look into the master cylinder.
This stuff isn't cheap, high performance costs money.
Your life may depend upon your brakes.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 05-30-2006, 02:09 PM
randywebb's Avatar
take the carpet up and look in the pedal cluster area - what do you see?
get under the car and look around right below that also
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-30-2006, 03:04 PM
Natog's Avatar
I always put the fluid in the pressure bleeder. Is this a big no no?
Sorry to hijack, I hope a fluid change fixes your brakes.
1987 TL Cabriolet
Old 05-30-2006, 03:44 PM
Me like track days
It attracts water like nobuddies bidness. What essentially works out to be 'air on top of the reservoir fluid' is a much better idea and most of my customers use this method.
I used fluid in my bleeder wished I didn't, what a mess.
Old 05-30-2006, 07:09 PM
randywebb's Avatar
Thumbs down
and it is water that makes the brake fluid "go bad"
Old 05-30-2006, 09:00 PM
Like Bill said high and hard is correct. I think my brakes have a total travel of 1". One good way to check if your master is bad is put a ton of pressure on the pedal and hold it there. If the pedal goes down at all it is usually a bad master. You should bleed the brakes at least every 2 years. I use a vacume bleeder. They are nice and clean and work great except for on some clutches.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 05-31-2006, 04:58 AM
ok great...thanks for the advice guys...i will start with testing the pedal as suggested by dean. I just put in a new stereo, so i've had the carpets out and all looked clean.
If no dice, i'll swithch out the fluid. i'll use the pressure bleeder, and then get back to you guys and let you know what i find...how much ATE will i need? is one liter enough?
best, paul.
84 R5 T2
04 Suby Outback
Old 05-31-2006, 07:05 AM
Somatic Negative Optimist
Gunter's Avatar
Paul:
All of the above AND: Make sure that the pistons are not frozen (Rusted) in the calipers. Push the pistons back (Large channel-lock pliers between pads/calipers) and press them out a few times with the pedal.
When pistons are not exercised, they rust in the calipers.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-31-2006, 07:52 AM
ok...i will try to get to this tonight/tomorrow and report back.
paul.
84 R5 T2
04 Suby Outback
Old 06-01-2006, 07:31 AM
Navaros911's Avatar
Not much I can add... but one liter is enough. As suggested, get the ATE stuff as in our host's catalog.
First find the source, then report back and you will get tons of tips on how to solve it.
I did my entire brake system one year ago and it wasn't that difficult (rebuild calipers, replace lines, replace MC and MC feed lines and pressure bleed it three times). We'll guide you through the process.
Don't use the fluid in the pressure bleeder, doing this makes a mess (as said before). Bleeding like this takes less than an hour or so for me, including putting the 911 on stands.
'94 964 - Celebration 30 Jahre edition
'06 997 - arctic silver with cocoa interior - sold
'77 RoW 911 - black and still sexy - sold and I miss her
'05 Audi A3 Sportback 1.9TDI (not a bad daily driver) - gone
Old 06-01-2006, 07:45 AM
I just drove my car and checked the brake travel. It is between 1" and 1.25" to rock hard. More on the 1" side I think.
Dean
Old 06-01-2006, 09:59 AM
ok, i'm gonna check travel and pedals and such tonight.
84 R5 T2
04 Suby Outback
Old 06-01-2006, 10:35 AM
