Make Bruins Great Again
Por_sha911's Avatar
Computer Chip Question-SW are you out there?
A friend of mine has an `85 ROW. I runs strong up to 5500 RPM and then cuts out like the rev limiter is kicking in. It is my understanding that the limit should be even higher than the USA 6250.
Questions: Am I right about the RPM limit? Can he replace in with a NA 24 pin chip?
Joe
Old 05-30-2006, 10:00 AM
Contact him through his website. He responds rather quickly.
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 05-30-2006, 11:18 AM
Steve W's Avatar
Most likely he has another issue, like a bad rpm sensor. The minimum rev limiter is always 6520. If suspects the chip is bad, he can install a stock chip an see if the symptoms continue to occur. If it goes away, have him contact me for a exchange. I though have never seen a low rev limit issue attributed to a chip though.
Old 05-30-2006, 11:53 AM
Por_sha911's Avatar
Steve: thanks for the reply. Can he use a NA chip in an ROW car?
Joe
Old 05-30-2006, 07:33 PM
Steve W's Avatar
Joe - as long as it's a 24 pin chip and it starts, should be good enough for testing. If the chip is from an 87, and his DME is not 4k enabled, then it may not start until the 4k jumper mod is done.
Old 05-30-2006, 09:24 PM
