plymouthcolt's Avatar
COnfused over 8 or 10mm bolt for cv joint
I need to clean and repack my cv joints and I'm ordering new bolts.
Pelican has for my '88 a 911 CV Joint Bolt, 10x50mm (late 1985-89), part 900-067-123-01.
The bolts currently on my car are 8mm with washers.
Do I reorder the same 8mm, or do I order the 10mm?
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 05-28-2006, 10:36 PM
Make sure you're not confusing the wrenching feature (inside hex in the head) size with the bolt size. The bolt size is the diameter across the threads.
Old 05-28-2006, 10:49 PM
Hmm...I guess I have to go measure. My bolts use allen socket size 8.
Howard
2003 996tt
Old 05-28-2006, 10:56 PM
8mm key size is the wrenching feature size for M10 socket head cap screws; you have 10 mm bolts installed.
Old 05-28-2006, 11:06 PM
randywebb's Avatar
for next time, ...
it might be handy to pick up a metric bolt gage at a fastener store -- you drop the bolt thru various holes, biggest it fits in is the size; also usually have thread gages on them
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-29-2006, 10:41 AM
rnln's Avatar
Jim Sims,
umm.. if my bolt fit the alen socket 8mm, then the bolt is M10. Then if the alen socket size 10mm fit the bolt, the bolt is 12mm? For example the transmission drain and refill plugs?
Fat butt 911, 1987
Old 05-30-2006, 01:59 AM
Tut Tut is offline
Howard,
If you need new Schnorr washers let me know.
Tut
Tut
'87 Carrera coupe
'08 BMW 535 xiT
Old 05-30-2006, 04:50 AM
randywebb's Avatar
rnln, maybe - and maybe probably - that is why a bolt gage is a good thing - get a cheap plastic one, or just measure the bolt size carefully
or size it by using a known nut ...
Old 05-30-2006, 12:07 PM
rnln's Avatar
Tut,
If you have some extra, can I buy off you, after Howard has his? And I appreciate it.
Fat butt 911, 1987
Old 05-30-2006, 12:28 PM
For metric socket head cap screws: M8 takes a 6mm hex key, M10 takes an 8 mm hex key and M12 takes a 10mm hex key.
For more information on metric socket head cap screws:
http://www.metricmcc.com/catalog/Ch1/1-32.pdf
Pipe and drain plugs are likely different; look'em up.
Old 05-30-2006, 01:57 PM
rnln's Avatar
Thanks Jim,
Fat butt 911, 1987
Old 05-30-2006, 02:18 PM
Originally posted by Tut
Howard,
Tut
I sure do. If you would email or PM me the details to order.
Howard
2003 996tt
Old 05-30-2006, 03:59 PM
