-   -   Finally, Wevo parts for my own car....... SPS install (http://forums.pelicanparts.com/porsche-911-technical-forum/285467-finally-wevo-parts-my-own-car-sps-install.html)
Walko 06-01-2006 09:37 PM
Awesome write up on supension mods. What did you do to the front suspension.?
Michael
Steve@Rennsport 06-01-2006 11:35 PM
Originally posted by jpahemi
Just got back from WEEEEEEVO test drive; these plates are amazing, smoother ride and no additonal road harmonics. I need to find a way to cap the torson bar entrance to avoid debris build up. The cotter pin could hold the cap on very nicely.
j.p.
JP:
Just get some Cap plugs of the correct size (same thing Weltmeister uses) and pop them on. If you put some small holes on the edges, the cotter pin holds them on.
The newest generation of WEVO SPS's have alloy plugs that do the same things,.....:)
mjshira 06-02-2006 05:27 AM
I think putting these on my car by myself would be beyond my whimpy wrench skills but man do they look slick! nice write up. would be interested to see if they help Scrappy get some lower times...
jpahemi 06-02-2006 09:13 PM
Steve:
I found these vinyl caps from McMaster-Carr.
They'll fit the OD of the plate body and are 1" deep
http://forums.pelicanparts.com/uploa...1149307964.gif
j.p.
jpahemi 06-02-2006 10:45 PM
Tyson:
Do you find that with the 80% LSD and SPS that the car wants to push to the outside during lift on long sweepers, or does the nose tuck in?
j.p.
Steve@Rennsport 06-03-2006 01:03 AM
Steve:
j.p.
Thanks, JP! Those look nicer than the Cap plugs for sure.
jpahemi 06-03-2006 01:08 AM
Steve:
Do you have any pics of what Wevo is using?
J.p.
Asjac 06-06-2006 07:40 PM
Smart Racing says to inquire about 87-89, what's the deal?
jpahemi 06-06-2006 08:12 PM
I have found these vinyl caps for the SPS plates; what do you guys think?
http://forums.pelicanparts.com/uploa...1149649822.jpg
http://forums.pelicanparts.com/uploa...1149649860.jpg
http://forums.pelicanparts.com/uploa...1149649896.jpg
http://forums.pelicanparts.com/uploa...1149649929.jpg
jp
Ps. you can use the cotter pin to secure the cap by piercing the cap from the outside or you can press the cap over the cotter pin.
CBRacerX 06-06-2006 08:36 PM
Please make these for 87-89!
cali74 06-06-2006 08:44 PM
jp - what's the part number on that cap? (Saves me from measuring the OD of the SPS.) Thanks!
jpahemi 06-06-2006 09:47 PM
cali:
The part # is : 9753K77 from McMaster-Carr.
If you don't want to order a whole bag I could send you a pair, just cover postage; good?
j.p.
cali74 06-06-2006 10:05 PM
sweet, sounds good! I'll pm my address, then lemmi know how much you'd like :-)
THanks!
randywebb 06-06-2006 10:26 PM
cap look like it'll do the trick - might make a note inspect yearly as it could degrade with time or impact...
jpahemi 06-06-2006 10:41 PM
randy:
I'm going to put a dab of grease in the cover to seal any potential water leaks. I have the hollow bars and don't like the idea of the open access hole.
j.p.
Tyson Schmidt 06-06-2006 11:38 PM
Tyson:
j.p.
The nose tucks in. It's just a smoother transition than before the SPS. Throttle-on gives some push, and lift tucks in the nose.
That's typical. The biggest difference was that I found I need much less steering correction after installing the SPS when encountering mid-corner bumps, or abrupt throttle inputs while cornering.
It's like buttah!
911-32 06-07-2006 02:01 AM
Did I miss an answer on the G50 question?
jpahemi 06-07-2006 02:49 AM
Yes, mid corner bumps are much smoother now; the car just glides over them without any sideways hop. The set-up seems to remove the sharp edges off the road/track imperfections; kind of like driving with a pillow under your ass. Now if I could get this same effect for the front!!!!!!
j.p.
TheMentat 07-19-2006 10:18 AM
+1?
randywebb 07-19-2006 11:46 AM
JP - are your comments also based on the SPS vs. new stock bushings, or old ones, or...
Walko 07-19-2006 04:16 PM
OK, where do I buy these products, I did a search and our I could not find a SPS in suspension on our hosts website and then I looked at the Wevo website and there was no information there.
HELP
Michael
Britain Smith 07-19-2006 04:55 PM
More info will be on there website soon...they are almost done major changes. I saw give it a couple more weeks.
-Britain
lateapex911 07-19-2006 05:30 PM
Or use the phone. Hayden or Tyson can fill you in. It is THE product for the back of a 911
jbrinkley 07-19-2006 05:30 PM
what's the word on g50's and g50 tranny mounts. If the mount was made and I missed it can someone point me n the right direction.
