-   -   Finally, Wevo parts for my own car....... SPS install (http://forums.pelicanparts.com/porsche-911-technical-forum/285467-finally-wevo-parts-my-own-car-sps-install.html)
Tyson Schmidt 05-29-2006 01:07 PM
The before shot. Notice the 964 oil tank installation. (never have gotten around to posting a thread on that one)
http://forums.pelicanparts.com/uploa...1148931908.jpg
The Elephant Racing Poly-bronze are currently installed, which are great, but the Wevo SPS has some distinct advantages. And of course, I got a great deal on them since I now work for Wevo.
http://forums.pelicanparts.com/uploa...1148932179.jpg
http://forums.pelicanparts.com/uploa...1148932209.jpg
With the old springplates out, and the opening cleaned of all the dirt/rust, It's time to fit the inner bearing carrier. I scribe a mark on the carrier, and tape a mark to the car so I can keep it indexed properly while shaping the carrier to fit the opening.
http://forums.pelicanparts.com/uploa...1148932287.jpg
Checking the fit of the cover to the mounting spuds. Luckily, mine are flat, and straight. Usually it's necessary to straighten them to line up properly with the holes on the cover.
http://forums.pelicanparts.com/uploa...1148932459.jpg
I'm also lucky, in that I only required shimming on the lower rear mounting point.
http://forums.pelicanparts.com/uploa...1148932622.jpg
One thick, and two thin shims makes it perfect. After tightening everything up without the torsion bar in yet, it moves freely with no pre-load whatsoever.
http://forums.pelicanparts.com/uploa...1148932707.jpg
Here's the right side completed. An added bonus was the fact that I can install the torsion bars after verything else, which made it possible to install the SPS without having to remove the oil tank. Normally, with a stock spring plate, the torsion bar would have to go in first, which would've required more room to get the spring plate over it.
http://forums.pelicanparts.com/uploa...1148932824.jpg
Left side nearly completed
http://forums.pelicanparts.com/uploa...1148932987.jpg
Now all that's needed, is to put the angle finder on the springplate, hold the spring plate at the angle that I measured the old one, and slide the torsion bar in. Mine are hollow, making it even easier to turn to just the right position that will alow it to slide right in at the appropraite spring plate angle. Fine adjustment can be made with the adjuster screw to get it perfect.
I always hold upward pressure on the spring plate during all angle measurements to take out the slop, and make it as accurate as possible.
Note: Due to the lower amount of stiction in the SPS, it will actually raise the ride height by 10mm typically. I compensated by reducing the spring plate angle by .5 degrees.
randywebb 05-29-2006 01:14 PM
Thanks, Tyson.
What are the advantages for a street only car?
jester911 05-29-2006 01:22 PM
Very nice Tyson, what would those run for us mere mortals?:D
Tyson Schmidt 05-29-2006 01:30 PM
Originally posted by randywebb
Thanks, Tyson.
Well, I am a big fan of the Elephant Racing Ploy-bronze solution, but the SPS does have some advantages. No maintenance, smoother action, (I was actually quite surprised by that, since the ER set-up was such an improvement over stock) and easier adjustability. It's also less work to install, since you don't have to remove any rubber bushings and clean and prep the old spring-plates.
The thing that really surprised me on the test drive, was that my 80% LSD with high pre-load, was no longer causing inconsistent handling.
The complete lack of friction really smothed out the small suspension movements, so much so, that the inside rear wheel was making better contact with the ground, which kept the cars attitude in a corner much more consistent. Before, any throttle input or pavement undulation would alter my car's trajectory, and I'd have to compensate.
It would likely be much less obvious on a standard diff. But I'm very happy with it. I did notice that afterwrds, it feels like I need to adjust the rear shocks a little firmer to re-balance the handling. I really wasn't expecting the difference to be much compared to the ER set-up.
For a street car, it is definitely a smoother ride, while still keeping the handling. It definitely gives you all the benefits of stiffer springs/shocks, but with less of the ill side-effects. I'd say it gives nearly as much improvement over the ER poly-bronze, that the ER poly-bronze gives over stock. And that's not taking anything away from Chuck's excellent product. I plan to use his poly-bronze bearings in the future anyime the customer choses them.
Tyson Schmidt 05-29-2006 01:39 PM
I'm not sure, actually. I think they are $980 for everything, IIRC. Pelican carries them, so they should be in the catalog.
Sounds like a lot of money, but if you factor in the spring-plates, (which are included, and easier to adjust than stock units) and the reduction in labor hours to install, it looks very attractive. (not too hard on the eyes either!)
In all honesty, I installed them on my car more to represent Wevo, and wasn't expecting much, if any improvement over the Poly-bronze bearings. But I was pleasantly surprised.
Dutchie 05-29-2006 01:47 PM
Looks great Tyson ! those welds are a work of art the man who did those can be proud :cool:
don911 05-29-2006 02:34 PM
Tyson,
I couldn't find these on pelican. I have polybronze bushings in the garage ready to install. Your comment about zero maintenance and easier instl has me interested. Where can I get more info on these? I've never seen them on wevo website.
Tyson Schmidt 05-29-2006 03:03 PM
Originally posted by don911
Tyson,
If they aren't in Pelican's catalog, I know for certain that you can call them and order them. We do business with them all the time.
Sorry about the website. The new website is nearly done, and will have all the appropriate updates soon.
Hey Noah, the best way I can describe the upgrade is that with stiffer torsions and shocks, you still get all the roll control, anti-squat, quicker transition and stability benefits that those provide, with less of the ill side effects cause by the spikes in loading in the frictional surfaces, or the distortion of the rubber bushings.
It's just so smooth, that it's indescribeable. Ask anyone who's got them. I can't wait to try turn 8 at Willow Springs with these things on my car. No doubt the bumps in the middle of 8 will be much less unsettling to the car. Or turn 2 for that matter.
If you eliminate the spikes in tire loading, you increase the tire's grip, and improve the predictability of breakaway. Not to mention the improvement as it relates to the LSD and how it affects the attitude of the car like I mentioned before.
rexav8r 05-29-2006 03:22 PM
Tyson, you dirty RAT !!!!
That's fantastic !!! Nice write up too.
First, I was a bit surprised to see that you were using non-adjustable spring plates with the poly-bronze, before swapping over...
I just put Neatrix on mine last spring. (I've got non-adjustable plates too.) I wanted to go ER, but had to limit the budget somewhere as I pretty much did the entire rear suspension and part of the front.
How does the torsion bar fit in there "after the fact" ? I know that there are different number of splines between the inner and the outer end of the bar, but is there a different diameter too ? Or do the splines line up enough to slide it through ? Regardless, I know that's how you did it, and it seems to me that would be the PERFECT solution to design ! What you couldn't (or didn't want) to adjust out with the set screw you could easily re-index the bar without a complete dis-assembly, which is a pain !!
Is there then a retaining cap or plug that goes on to keep the bar in position and gunk out ?
That's AWESOME !
Tyson Schmidt 05-29-2006 03:36 PM
Richard, those are factory adjustable spring plates on my car in the before pic. Problem with those, is that they require special wrenches, and the car needs to be raised in the air to adjust them. And since they are an eccentric, there is no direct correlation between the adjuster movement and the height change.
With the adjuster screw style on the SPS, you can change the ride height in the future without losing the corner balance, so long as you move both set screws the identical amount.
Yes, the inner splines are smaller diameter, so the bar slides right in after the fact. What's nice about this is, you can change out your torsion bars at the track very quickly. Mine are hollow, so I was able to stick my finger in the hole and pull it back out. But even with solid bars, you simply push one side in, and that pushes the other side out. Then when you push the new one in on that side, the other one can be pushed out.
You're right about re-indexing to get the adjuster screw in a normal range. It's important not to have it set too far out once it's finally set, or it could lead to problems as the spring plate flexes during suspension movements.
rexav8r 05-29-2006 04:39 PM
Sorry, stupid mistake on the old spring plates.
Man, those with hollow bars is the way to go !! I didn't even think about the possibility of swapping out bars so easily !! Going from street to track would be pretty much a 5 minute task it seems. Once the bars were indexed anyway...
Is there some type of plug or pin that holds them in once installed ? I know people take pretty good precautions to keep the torsion bars (not to mention the tube) corrosion free.
Tyson Schmidt 05-29-2006 04:50 PM
Yes, there is a cotter pin on each end to keep them in. As long as you grease the splines, you'll be fine.
I think Elephant Racing has caps for the hollow torsion bars they sell. I got my bars from them.
Don Plumley 05-29-2006 05:01 PM
I see you are exercising the garage - you'll be ready for me on Wed? ;)
I took care of the bad toe-in and lowered it about 1.5" to get it in the right neighborhood. She's waiting for your evil touch...
Tyson Schmidt 05-29-2006 05:18 PM
Great to hear Don!
As you can see, I'm setting up the scales today. I'll definitely be ready by Wed. to set-up your 993.
You must be like a kid 3 days before X-mas, eh?
When you get here, I should have you drive my car and post your impressions here.
Don Plumley 05-29-2006 05:46 PM
I should probably bring some Depends!
Tyson Schmidt 05-29-2006 06:53 PM
You scare yourself while driving?
Jeff Alton 05-29-2006 06:54 PM
Tyson, not sure I understand how less friction meant the ride height was raised. Should it not be the other way around? Would the friction not lead to an increase in spring rate of sorts (for lack of a better term)? It would seem to me that if you remove the friction you would see less resistance suspending the car and a lower ride height.
Cheers
304065 05-29-2006 06:55 PM
Well I now have the first item on my list of next seasons mods.
Tyson Schmidt 05-29-2006 07:12 PM
Cheers
That's what I would've thought too. But remember, the friction tends to keep it where it last was, so when the suspenion compresses, the torsions are working against gravity, the weight of the vehicle, and the stiction of the suspension to try to raise the car back up to ride height.
I set the spring plates .5 deg lower, and the car still seems higher than before.
I'll freely admit, it seems counter-intuitive at first.
Oh, and John C., you won't be sorry!
Hayden actually had to talk me into swapping from the Elephant pol-bronze to the Wevo SPS because I thought it would be a lot of work for nothing. But now I'm really glad I did it.
I was actually going to remove my 80% LSD and lower the pre-load on it because I didn't like the handling characteristecs, but now with the SPS, it feels just fine. i really wasn't expecting that one.
Jeff Alton 05-29-2006 07:34 PM
OK, that makes sense, thanks for the explanation! :)
Cheers
Mahler9th 05-29-2006 09:15 PM
Thanks for the info. Wevo make some nice parts-- it is hard to beat the quality and engineering. We are lucky to have companies like Wevo, SRP et cetera to make such nice parts.
My suspension is "fixed" and has rear coilovers. No need for fancy spring plates, but they look cool for a street/track car.
By the way Tyson, if you want some 993 multilink set up hints, check out Hank's car. I am pretty sure that is nearly 100% multi-link, and Mat set it up.
jpahemi 05-29-2006 09:51 PM
Tyson:
Did you replace the bannana arm pivot bushing (rubber)? How much shaping did you need for the bearing carrier to fit?
Thanks,
j.p.
Tyson Schmidt 05-29-2006 10:20 PM
Yes, I've already got Elephant Racing's sealed mono-ball cartridges on the semi-trailing arms.
Mike, who are Hank and Mat?
I'm always open to input, but I also have my own set-up preferences. Those are usually proprietary, so I'm not willing to share, and I bet Mat isn't either. Rear bump-steer in particular is a very personal thing.
Are you talking about Hank Watts? His '72 beast?
jpahemi 05-29-2006 10:23 PM
Thanks,
j.p.
Tyson Schmidt 05-29-2006 10:26 PM
Thanks,
j.p.
Not much. I just made sure to smooth out the torque tube and clean up any imperfections. Then just needed to knock down a few spots, and tapped them in lightly with a small plastic hammer.
don911 05-29-2006 10:32 PM
so these take the place of the spring plate and the rubber bushings? In other words, if I put these on, I don't need additional bearings and I can sell my polybronze bushings I had planned to install.
The Chef 05-29-2006 10:32 PM
Cool writeup. Here is a pic that i took from German Auto Fest a couple of years ago. Its really nice looking stuff. I would like to know how it feels on the track. Keep us updated.
http://forums.pelicanparts.com/uploa...1148966906.jpg
Tyson Schmidt 05-29-2006 10:48 PM
Yes, it includes all of it. you can sell your existing spring plates, bushings and covers.
Britain Smith 05-30-2006 02:39 PM
I also have the spring plates in my car. I have yet to drive my car with them, but I have riden in Haydens car and they felt awesome! Such a quality product and they included everything that you need to install them.
-Britain
http://www.britainsmith.com/Porsche/...3_0014_JPG.jpg
I was part of the first set that got made so I am not sure if the kits have been altered any since. I know that additional shims are included now for example.
http://www.britainsmith.com/Porsche/...3_0010_JPG.jpg
http://www.britainsmith.com/Porsche/...3_0013_JPG.jpg
Tyson Schmidt 05-30-2006 06:47 PM
Britain, there have been a few minor changes from the intial batches.
Mainly done to help them fit a wider range of chassis' that may be farther out of factory tolerances from accidents, or wear and tear.
don911 05-30-2006 09:29 PM
Tyson,
You're about to cost me some $. :) Are those bearings sealed up after installation? Are the bearings replaceable and how often?
Tyson Schmidt 05-30-2006 10:06 PM
Tyson,
Yes, they are sealed. The outer bearing is a sealed bearing, and the inner one has a lip seal that is installed after the bearing is mounted in the carrier. So it's all weather-proof.
So far, no need for replacement on any of the kits out there, and no signs of any wear either. It seems sufficiently over-engineered in that regard.
Many of the original kits that were distributed for testing were used on track cars seeing very high loads.
lateapex911 05-30-2006 10:42 PM
I put the SPS system on my car last summer, and I really think they are the way to go.
At first, you suck a breath back when you hear the price.......but...quick math shows that they are right there where they should be when you compare apples to apples. A set of adjustable spring plates, and a proper T bar/spring plate bushing set up runs nearly the same money.
But..the WEVO stuff is just NASA grade. Hayden hit another home run with these. The build quality is just sick.
On mine I got the carrier very close, then froze it and it slipped right in. and no preload on mine either. Without the T bar in place, the springplate just falls through it's arc when you let go.
Tyson didn't mention the instruction manual. So much information is in there. This is a company that really has their s#!t together. And.......if you need tech help, just call Tyson!
Finally, I upgraded my tbars and dampers at the same time I installed these, and the Elephant polybronze setup for the front, with a Smart Racing sway bars, and I was worried it would be too stiff. Nope...not even close. Actually, I could go much stiffer. It rides effortlessy now.
don911 05-31-2006 11:46 AM
Talked to Glenn at pelican today. He said these are for pre G50 cars. Tyson is that correct?
If so, do you know if there are plans in the VERY near future for these spring plates for G50's. I will volunteer as a test vehicle if required. :)
Also, please make a replacement for the NLA G50 tranny mount assy that incorporates replaceable mounts. I'll test this unit as well.
randywebb 05-31-2006 12:50 PM
"A set of adjustable spring plates, and a proper T bar/spring plate bushing set up runs nearly the same money."
- Only true if you buy new spring plates and need quick adjustments. My used pair of late model (cams) stock plates cost very little. The rubber bushings are only $70. So, that's an order of magnitude... 10x in price.
I have no doubt they are a superior product, but regardless of relative cost, the absolute cost means I'll have to wait for Suspension, Phase II -- i.e. a few years.
CBRacerX 05-31-2006 01:17 PM
+2 on the G-50 Test Car list :)
They look great! Now you DO need to give us a thread on the 964 Oil tank - I have been very interested in doing that and the engine is out of the car at the moment...
lateapex911 05-31-2006 01:25 PM
Well, quite right Randy..I should have been specific that I was referencing the upgrades of equivilent performance and quality.
So that would be something with an easy adjustment, and anon rubber bushing. Something like Chucks stuff.
I think, with those considerations, and when you factor in a mechanics time, the WEVO stuff is actually the value proposition.
vash 06-01-2006 08:44 AM
dude! that is sweet, really sweet.
you should really get them to pay you with cash! :)
randywebb 06-01-2006 01:20 PM
I agree - if you don't DIY, then the price differerential is reduced, maybe to zero. I hope to put these on my car someday too....
Yeh - Oil tank thread -- I'll even start it for you Tyson.
jpahemi 06-01-2006 07:45 PM
Just got back from WEEEEEEVO test drive; these plates are amazing, smoother ride and no additonal road harmonics. I need to find a way to cap the torson bar entrance to avoid debris build up. The cotter pin could hold the cap on very nicely.
j.p.
