Awesome write up on supension mods. What did you do to the front suspension.?
Michael
Old 06-01-2006, 09:37 PM
Originally posted by jpahemi
Just got back from WEEEEEEVO test drive; these plates are amazing, smoother ride and no additonal road harmonics. I need to find a way to cap the torson bar entrance to avoid debris build up. The cotter pin could hold the cap on very nicely.
j.p.
JP:
Just get some Cap plugs of the correct size (same thing Weltmeister uses) and pop them on. If you put some small holes on the edges, the cotter pin holds them on.
The newest generation of WEVO SPS's have alloy plugs that do the same things,.....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-01-2006, 11:35 PM
Sports Purpose 911 Driver
mjshira's Avatar
I think putting these on my car by myself would be beyond my whimpy wrench skills but man do they look slick! nice write up. would be interested to see if they help Scrappy get some lower times...
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 06-02-2006, 05:27 AM
jpahemi's Avatar
Steve:
I found these vinyl caps from McMaster-Carr.
They'll fit the OD of the plate body and are 1" deep
j.p.
Old 06-02-2006, 09:13 PM
jpahemi's Avatar
Tyson:
Do you find that with the 80% LSD and SPS that the car wants to push to the outside during lift on long sweepers, or does the nose tuck in?
j.p.
Old 06-02-2006, 10:45 PM
Steve:
j.p.
Thanks, JP! Those look nicer than the Cap plugs for sure.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-03-2006, 01:03 AM
jpahemi's Avatar
Steve:
Do you have any pics of what Wevo is using?
J.p.
Old 06-03-2006, 01:08 AM
Smart Racing says to inquire about 87-89, what's the deal?
1987 911 sunroof - just starting out on that slippery slope =-D
Old 06-06-2006, 07:40 PM
jpahemi's Avatar
I have found these vinyl caps for the SPS plates; what do you guys think?
jp
Ps. you can use the cotter pin to secure the cap by piercing the cap from the outside or you can press the cap over the cotter pin.
Old 06-06-2006, 08:12 PM
CBRacerX's Avatar
Please make these for 87-89!
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 06-06-2006, 08:36 PM
cali74's Avatar
jp - what's the part number on that cap? (Saves me from measuring the OD of the SPS.) Thanks!
74 911 with '95 3.6l
Old 06-06-2006, 08:44 PM
jpahemi's Avatar
cali:
The part # is : 9753K77 from McMaster-Carr.
If you don't want to order a whole bag I could send you a pair, just cover postage; good?
j.p.
Old 06-06-2006, 09:47 PM
cali74's Avatar
sweet, sounds good! I'll pm my address, then lemmi know how much you'd like :-)
THanks!
Old 06-06-2006, 10:05 PM
randywebb's Avatar
cap look like it'll do the trick - might make a note inspect yearly as it could degrade with time or impact...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-06-2006, 10:26 PM
jpahemi's Avatar
randy:
I'm going to put a dab of grease in the cover to seal any potential water leaks. I have the hollow bars and don't like the idea of the open access hole.
j.p.
Old 06-06-2006, 10:41 PM
PRO Motorsports
Tyson Schmidt's Avatar
Tyson:
j.p.
The nose tucks in. It's just a smoother transition than before the SPS. Throttle-on gives some push, and lift tucks in the nose.
That's typical. The biggest difference was that I found I need much less steering correction after installing the SPS when encountering mid-corner bumps, or abrupt throttle inputs while cornering.
It's like buttah!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-06-2006, 11:38 PM
911-32's Avatar
Did I miss an answer on the G50 question?
Old 06-07-2006, 02:01 AM
jpahemi's Avatar
Yes, mid corner bumps are much smoother now; the car just glides over them without any sideways hop. The set-up seems to remove the sharp edges off the road/track imperfections; kind of like driving with a pillow under your ass. Now if I could get this same effect for the front!!!!!!
j.p.
Old 06-07-2006, 02:49 AM
TheMentat's Avatar
+1?
Silver '88 RoW Carrera
Grey '06 A4 Avant
Old 07-19-2006, 10:18 AM
randywebb's Avatar
JP - are your comments also based on the SPS vs. new stock bushings, or old ones, or...
Old 07-19-2006, 11:46 AM
