What do you anchor your canopy with at the track?
Ok-I purshased a 12 x 12 canopy at Dicks sporting goods and now need some ideas for anchoring the legs. I've considered using 25 lb concrete blocks, OR 5 gallon jugs that I'll fill with water once I get to the track. Any other creative ideas out there that have been tried and tested? TIA
1980 911SC Targa 3.6L |
Sometimes we use wheels/tires and ropes.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
I saw some guys use a busted tranny from a 914 once.
Grady Clay and company use their tow vehicles...which are very unlikely to blow away.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Okay, this has got to be one of the smartest, easiest, cheapest ideas ever. I didn't invent it but wish I could claim it.
Saw a guy at the Colorado River with a stack of children's sand buckets -think Big Lots or The 99 Cent Store. He would use a fairly long bungee cord and one or two big red sand buckets at each corner. When done, empty the buckets and they stack one inside the other. The bungees go in there too. Okay, you're at the track, I don't know what to tell you to do about the lack of sand. Maybe bring along one bag of kiddy sand from HomeDepot and dump it before you return or use soil froma flower bed? But it works and takes up almost no space. Good luck, Dan
Dan in Pasadena '76 911S Sahara Beige/Cork |
Use some nylon stretchy rope and some weights from a dumbell set. You can keep adding weights at the corners if it gets windy.
I'm assuming you're talking about the ez-up kind or something like that. The ones I've seen have a flat part on the bottom of the legs with holes in them. I've seen people drive stakes through them into the gravel in the paddock. Very sturdy and not much hardware to carry around.
'87 911 Coupe '95 911 Coupe '04 911 GT3 '98 Jeep Wrangler |
Diss Member
I weight it down with the bodies of dead competitors!
. . or On asphalt I have used concrete nails. On loose surfaces I have used the big screw in stakes, strapped it to tires, or strapped it to fences or support vehicles. It is a real problem.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Another idea - bungee it to 4 of those big screw-in things for tethering your dog in the yard! Cheap & lightweight.
spare set of mounted rains/slicks/streets does the job just fine
dave 1973,5 |
don't the owners of the racing venue wig out when you make holes in the asphalt?
Tent/canopy tie down is critical for safety. A few summers
ago we were at an event and the morning was nice and calm. Someone had a 10x10, possibly smaller, Ez-Up anchored to buckets of wet sand – probably 20-30# each. A slight mid-morning gust came along and flipped it onto a gray haired grandmother. She went down like a sack of potatoes. She was rushed to the hospital in a Flight-for-Life helicopter. Vehicles are also at risk. I was at an SCCA race about five years ago and an afternoon big gust came along and flipped a 10x12 awning off the side of an enclosed trailer. It had three polls, each with two 6-gallon full plastic fuel bottles (~50# each). The gust flipped the bottled up and then down onto the fender & bed of the guy’s new dualy crew cab. It bent the fender and side of the bed down and around the dual rear tires. I can only imagine what it would have done to a 911 – the roof would have been flush with the seat cushions. There is a lot of sail to even a small canopy. Any sailor will confirm that. First, be prepared to take down the tent/canopy if the wind picks up. This is particularly true with afternoon thunderstorms. Devise a way to get it down fast. Tie the frame to very substantial vehicles. Big heavy trucks are best. Passenger cars and trailers will do. Even better are substantial telephone polls, fence posts and the like. Tie to them near the ground. Tie down at least three sides and be prepared to tie the fourth side to some vehicle. Bungee cords with hook ends are not suitable to tie down a canopy unless you use a LOT of them. Even then they can come loose when overstressed and snap back and injure someone. I use 1”x16’ ratchet cargo straps. I try and use at least two at every poll and they are looped around the canopy corner pieces. Each end has a hook and D-ring that allows you to wrap around a frame member, spring shackle, bumper support, telephone poll, etc. and not have it come loose accidentally. These straps are rated at 835# working load, good to 2500# and not fail. With 16+ straps per 20x20’ canopy, strap strength isn’t an issue. In case quantity (25) they are under $10 each. They are Kinedyne part number: 711681/45PK, trade name: ”Strap-All”, proper description: “Ratchet Strap with hooks and D rings.” At La Junta, CO we are lucky. There are still aircraft anchors in the concrete paddock. If a B-17 wouldn’t blow away 60 years ago, our “little” tents are pretty secure. I am going to see what it will take to buy some old elevator ¾” steel cable and tension it through all the aircraft anchors. Best, Grady |
Rumor has it you guys in the southwest just handcuff an illegal alien to each corner
'95 993 C4 Cabriolet Bunch of motorcycles |
Dang hurricanes always ruin racing anyways
