Troll Hunter
Targa wind noise
Here are some pix. I just got this car the other day and didn't notice the air noise, maybe because I had the windows down, or maybe because I took the top off and replaced it...incorrectly? It's pretty loud inside and coming from the windshield. Is this normal?
I took the top off again, lubed the rubber hoping for a better seal, but it's the same. The rubber looks in good shape. Am I nuts? Nick ![]()
the front lip of your Targa top seems to sit too high over the windshield frame. That could be caused by an incorrect front Targa seal or possibly misalignment of front latches. I would check with Dan Pechtel, the Targa top specialist. He has a post here:
Targa Top Tech
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Fleabit peanut monkey
What is the condition of the seal? Does it look brand spankin' new or kinda like 30 years old?
1981 911SC Targa |
Troll Hunter
Thanks Bob, thanks Wolf.
I put some electrical tape over the seam just to see if it would affect the noise. It limited it, but the noise was still there. My seal is not brand spanky new...probably original. I'm thinking it needs a new one. I'll contact Dan. Thanks guys. Nick |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Targa Top.
Replacing these parts elimenated all wind noise & rattles on our '86.
Good luck, Gerry ![]()
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Vintage Owner
Targa top noise
Definitely get the seal from Dan. The one that Porsche sells is an updated part number for the 964, and doesn't fit correctly from what I've been told.
PCNA did have a booklet on sealing the 911s from wind and water intrusion. There is an additional seal that can be installed to help fill that front gap that is mentioned in the booklet. The part number is 911.799.565.25 and it fits along the front edge, 5mm below the top. I think the PDF of this technical booklet is available as a PDF somewhere, though I don't have a link. Maybe someone has it available as it covers a lot of sealing issues.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Also note that if your top is old, the skin will lift from the frame at speed (Venturi effect) making lots of noise. This is my current situation, similar sounding to your issue. Rebuild necessary.
Troll Hunter
Thanks guys.
Strike, I'm sure the venturi effect is contributing to the noise; no doubt about that. Gerry, I'm not sure how replacing those pins and covers would affect the windshield seal, but I'll check them out. Jack Stands, thanks for the part number. I'm waiting to hear from Dan. Nick |
Spend the $1000 or so and have him restore the entire top from the looks of it, it's due.
I had Dan restore the top on my 82 and the improvement in wind noise and fit was dramatic. Take the car to him so he can do the proper measurements, renew seals and fitment.
2021 Spyder 2019 Carrera T 2007 911 GT3 1973 911E RGruppe #295 |
Nick,
To chase down wind noise in my coupe, I used blue painters tape. Easy on and off without paint damage. I was amazed how much wind noise was caused by an old windshield gasket. Try taping around the windshield first, then tape around the leading edge of the Targa top. I even taped off the passenger door and rear window. Replaced both the front and rear window gaskets. Made a huge improvement. Good luck, Tony
Tony 1973 914 2.2 FAT Black 1974 911 Targa Lime Green 2018 Macan GTS White 2019 Targa GTS Agate Grey |
I need to replace the seals on mine, but holding off on the top itself for a while longer. I'd like an idea of what makes it necessary sooner than later (sound aside, of course). Thanks.
GP White '84 Targa |
Targa is a German word meaning 'Noise is directly proportional to speed'
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!. 1977 911S 2.7 to spend money on 2006 Tundra for acting grownup |
Our host lists 911-799-565-25 piping as NLA.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
when the top ages, the webbing gets stretched, and this makes the leading edge rise up- that's what it looks like is happening on your top
Check the hooks on the top are engaged in the recesses on the front beam, they can also wear and disengage when you are driving.
Jim Holmes
Bob C
I had a similar problem with my '74 Targa. I fixed it somewhat by first pressing down hard on the top with one hand and then tightening the latch with the other while keeping the pressure on the top, then move to the other side. Just trying to tighten it down while inside the car didn't put enough pressure on the top to get it in place properly and it kinda looked like yours. It's still a bit noisy, but not nearly as bad.... try that before spending $$$$....
Bob |
Vintage Owner
If that part is NLA, it is a simple " P" shaped rubber seal. Should be available at McMaster-Carr and others.
I'd agree that Dan is your best bet as he's the best at getting these things together correctly.
This is exactly what Dan will say needs to be done. Guaranteed. Got mine done by Dan in Feb and all of "other" irregularities were quickly identified.
1981 911SC Targa |
Troll Hunter
Here are some pix of the front seal. Upon inspection, the pin covers/receivers/plugs definitely need replacing, and certainly the venturi effect is a large contributor to the noise.
Does my seal look at least decent? ![]() ![]() BTW, I took off the sun visors. I hated the look. Will put em back on if the sun starts to bother me. Nick
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
Nick writes:
>>>BTW, I took off the sun visors. I hated the look. Will put em back on if the sun starts to bother me. I hated them also, so I cut them in half, right along the dotted line Porsche provided. Then I covered the whole thing, mirror and all, in alcantara (dash also). Now I really like how compact they are. ![]() Oh, and to the OP, the Targa top is only to be used when you're parked!!! Chuck.H '89 TurboLookTarga, 362k miles (360k or so top off) |
