registered user
vcp07's Avatar
proper lubricant
Any recommendations for lubricating moving parts on power seats?
Old 07-18-2011, 09:00 AM
Try Wurth HHS-2000 spray
Old 07-18-2011, 09:53 AM
registered user
vcp07's Avatar
thanks for the response
Old 07-25-2011, 08:08 AM
Member 911 Anonymous
DRACO A5OG's Avatar
The rails or the hinge for the recline?
If rails places some grease on the rails.
If the hinge, spray some silicone based lubricant, not WD40.
'85 Carrera Targa
PCA/POC
Old 07-25-2011, 08:30 AM
registered user
vcp07's Avatar
its the rails, do you have the name of a manufacturer and type of grease
thanks for answering
Old 07-25-2011, 09:13 AM
AutoBahned
RWebb's Avatar
any ol' white grease is fine; Wurth HHS-2000 spray is likely better if you have it
Old 07-25-2011, 12:01 PM
DRACO A5OG's Avatar
I got some Porsche Grease from Redline Tecnik, Mark. it is in a tube with a PAG number clear bronze in color, not cheap $21.00.
'85 Carrera Targa
PCA/POC
Old 07-25-2011, 04:12 PM
registered user
vcp07's Avatar
thanks
Old 07-26-2011, 06:52 AM
Almost Banned Once
sc_rufctr's Avatar
Off topic but...
Years ago I saw the glove box book for a then new 993. The spare key had a very thin smear of bronze/gold coloured grease on it.
I think that's the same stuff. Excellent find. Details like this are interesting to me.
- Peter
Old 07-26-2011, 06:58 AM
ive been really happy with dupont spray teflon lube. its not greasy like wd40 or pastey like some. i really like it for motorcycle chains as it dosent attract and let dirt stick to it.
Ryan- Sad day when my 83 911 left me
Old 07-26-2011, 10:41 AM
registered user
vcp07's Avatar
thanks
Old 07-26-2011, 11:21 AM
DRACO A5OG's Avatar
VCP,
I found removing the seat makes it easier to lube all the points on the rail and how it functions. Flip the seat upside down. I also re-torqued the bolts just for insurance.
Caution remove the #2 fues on Fuse Block #1 to avoid popping the fuse when you disconnect the power seats, they are constant hot leads and will blow the fuse if it touches metal. This also an opportune time to clean, re-crimp and place some heat shrink on the contacts. Of course, if you have power seats.
Jim
'85 Carrera Targa
PCA/POC
Old 07-26-2011, 11:30 AM
registered user
vcp07's Avatar
sounds like a good project
thanks for advice
vincent
Old 07-26-2011, 01:26 PM
