1975 911 pertronix usage
I recently purchased a used dist with pertronix installed to install in my 1975 sportomatic. what are the proper wiring precedures and connections that need to be made? dist is from a 2.7 with the pertronix installed. #'s on dist are 023101840607 and JFUD 6
if I remember you run the black wire to the coil and the red to a voltage source in the fuse panel in the engine bay. It's been a few years so I hope someone will chime in for you.
This thread has some info and diagrams down about half way.
http://forums.pelicanparts.com/showthread.php?s=&threadid=136004&highlight=pertro nix Pat |
I used a connector buss instead of soldering the Pertronix for a quick remove and replace.
http://forums.pelicanparts.com/uploa...1149211194.jpg |
| All times are GMT -8. The time now is 04:23 PM. |
