993 Alternator assembly problem
I took my alternator apart to change the bearing. I already assembled it again but I am having problems with the small plastic fan that goes in the rear part.
Does anyone know which direction should face it. http://forums.pelicanparts.com/uploa...1149211250.jpg |
Looking at the PET, it lools like your first post is correct. I would be supprized that you could get the end cover on if you had it the other way.
thanks
| All times are GMT -8. The time now is 03:46 PM. |
