-   -   Fog light question (http://forums.pelicanparts.com/porsche-911-technical-forum/286095-fog-light-question.html)
FenderGuy 06-01-2006 07:59 PM
Fog light question
So have any of you "do it yourselfers" found a economical way to replace the lens on 84-89 fog lights? Also why are they heavy? Anyway to lighten them up a bit?
nesslar 06-19-2006 03:19 PM
Oops! My bad, as one might say....:rolleyes:
Mondays can really be Hell...........
nostatic 06-19-2006 03:25 PM
rip 'em out and use the hole to cool the brakes
cbeers 06-19-2006 04:28 PM
Search for ZOANAS and I think Wil Ferch on this board. They did install some other lights.
If you don't use them though, do what nostatic says :)
I still use mine.
-Chris
JeremyD 06-19-2006 05:13 PM
Picked up my car from it's tech inspection and oil change -
It's running like a top -
Got home and one of my fog lights had a little breakerage...
http://forums.pelicanparts.com/uploa...1149863005.jpg
No problem - I have been working on a project anyway to add some more fresh air to the brakes and carrera oil cooler.
http://forums.pelicanparts.com/uploa...1149862883.jpg
Looks like a stock carrera - Stainless Steel mesh epoxied to the inside of the housing
http://forums.pelicanparts.com/uploa...1149863132.jpg
APC driving light mounted to the inside
Lights on
http://forums.pelicanparts.com/uploa...1149863339.jpg
with the flash to highlight the guts
http://forums.pelicanparts.com/uploa...1149863375.jpg
FenderGuy 06-19-2006 07:49 PM
Pretty cool trick there JeremyD thanks for the tip
rnln 06-19-2006 11:11 PM
JeremyD,
I'
ve seen something like that at any autopart store but never know if they really light up the road. How are their visibility?
Thanks.
JeremyD 06-20-2006 06:16 AM
As well or better than the existing fogs, which are maginal at best. I just went with the standard driving lap - being low like that does not help on the driving light end... But definitely better than stock
rnln 06-22-2006 10:20 AM
Last question regarding foglight, I went to autozone and found your type, also saw they have something with projector lense look like the pic below.
Do you know if the one with projector lense would give more lighting visibility?
Thanks.
http://imagehost.vendio.com/preview/...raz/PROJRD.jpg
ZOA NOM 06-22-2006 12:04 PM
-Chris
Somebody call??
These are Hella 450 driving lights. I do a lot of night driving, and they are flamethrowers. 1 mile pencil beams, and with my relay setup, I can use them with my high or low beams.
http://forums.pelicanparts.com/uploa...1151002829.jpg http://forums.pelicanparts.com/uploa...1151002976.jpg
Peter Bull 06-22-2006 01:11 PM
A pair of these might do the trick. Carbon fiber air ducts, weighs just 200 grams each.
http://forums.pelicanparts.com/uploa...1151006995.jpg
/Peter
Dadstoy 12-25-2006 09:37 AM
What is your relay setup? I just got some of those exact lights for Christmas and I'm trying to install them but I'd like them to come on with the High Beams only but run on the same switch on the dash.
Any ideas?
Dadstoy 12-25-2006 03:15 PM
Nevermind, we got it all figured out, and those 450s are Amazing!
ZOA NOM 12-25-2006 06:51 PM
Yeah, be prepared to get flashed if you forget to shut them down for oncoming cars. They will burn holes through trees.
