Jk369's Avatar
Black connector CIS where does it go???
I am putting the CIS back on (motor out) and to my disbelife i can not find where the last connector goes. BTW I have the green one on the throttle and the blue on the cold start.
'80 SC 911
'67 Chevy SS Nova - Supercharged
'99 GSXR track only, '99 Superhawk
'05 Toy PU - daily driver
Old 06-03-2006, 08:38 AM
Jk369's Avatar
Found it! Now if I only knew what the alum thing on right side of the motor with the big hoses going to it where the mistery connector goes was called.
'80 SC 911
Old 06-03-2006, 09:23 AM
Auxiliary air regulator or AAR?
AAR Revisited
Old 06-03-2006, 01:39 PM
Scott R's Avatar
Make sure you have those black plugs on in the correct locations, there are three that look exactly the same, except one of them is specifically for the frequencely valve. The other two have constant hots for the WUR and AAR. If you plug the wrong one into the frequencey valve it will melt and may cause fire.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-03-2006, 02:43 PM
Jk369's Avatar
Thanks for the tip, fortunately I only disconected the three to remove the CIS and then the wiring harness.
'80 SC 911
Old 06-03-2006, 07:07 PM
