Key locking difficulty
This started just today, when I close the door both fully closed, I tirn the key in the door handle and the lock mecjanism goes down then pops back up again not allowing me to lock the door, Is there an adjustment at the door latch perhaps that needs to be made?
Old 06-04-2006, 05:20 PM
What?
Eric Hahl's Avatar
That just happened to me yesterday. I had to lock it from the passenger side. Today I was playing around and hit the lock button on the center console before I got out of the car. Don't know if it had anything to do with it but I got out and was able to lock it from the drivers side again.
Maybe it was a fluke and the problem will show up again I don't know. Maybe someone can enlighten us both.
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 06-04-2006, 05:58 PM
Ken911's Avatar
hah good question my doors had to be taken apart for painting and when i re installed the handles the drives side and the passenger side will not lock with the key. and the driver side will not unlock that way either. dont know why it happened
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 06-04-2006, 06:01 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
I've been having this type of difficulty since I got my 911.
I have the fully automatic locks (if the central locking system is messed-up I can only unlock the doors from the outside).
Last week I took my passenger side door panel off to fix the door handle and experienced the same type of crap after I put the door back together.
At first it would lock on the driver's side only and unlock from the passenger side only. So I disconnected the microswitch wire in the passenger side door (the way the car came to me, go figure) and then the car would lock and a second later it would unlock both doors. Very aggreviating, so I tried with the ignition in positions 1 and 2 and each time I held the central locking button in (for about two seconds) the doors would lock and stay locked, but they wouldn't unlock when I pushed the button a second time. I would have to disconnect the battery to get them to unlock from the driver's side door. So I played with it for about two hours until it would lock and stay locked from the driver's side. So I went to work the next day (my 911 is my daily driver) and I locked the car. I waited a minute to make sure it didn't unlock itself, satisfied I walked away. After work I got to the car and it was unlocked!!! I was a bit POed this time. The Next day the electrical locking mechanism magically worked the way it used to (which I think is wrong because the passenger side microswitch is still disconnected so I can't lock the car from that side). I'm just hoping that the system stays working.
I feel for everyone else who has this problem, very aggreivating.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 06-04-2006, 07:51 PM
