goldsc78258's Avatar
Send a message via Yahoo to goldsc78258
CDI gone bad?
I went to start mi car today and it won't start. I went to the back and there is no whinning noise coming from the cdi box.
My question is before I go and get a new one, is there anything that could make it go bad from one day to the next?. Hell I parked the car yesterday and it was working fine.
Old 07-21-2006, 05:24 AM
Early_S_Man's Avatar
Porsche Crest
Most likely problem is old, corroded electrical connections ... maybe loose, too!
Check for + 12 Volt power at the 'B' connector of the CDI mating connector ... center Red wire. There are several connections between ignition switch and CDI unit ... at 6-pole connector under dash at fuse 7-8 buss connection, at forward 14-pin connector on electrical panel in engine compartment, at single-wire disconnect on heavy Red wire going to CDI 3-pin connector.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-21-2006, 07:23 AM
How do you test a CDI that is out of the car? I recently purchased a used CDI and would like to test it.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 07-21-2006, 02:05 PM
got it fixed! Thanks!
it was the ground wire it was pretty dirty and a little loose
Fred
Old 07-21-2006, 02:21 PM
