-   -   Front Rotor (http://forums.pelicanparts.com/porsche-911-technical-forum/286848-front-rotor.html)
911Gal 06-06-2006 09:39 AM
Front Rotor
Trying to replace rotors on front wheels. According to service records this will be the first time. I changed rears with very little problem. Moved to front and cannot remove the dust cap. Any suggestions?
ecm911 06-06-2006 09:55 AM
911Gal,
May sound funny but use two hammers. Place the claw end of one against the dust cap and use the other to hammer the hammer end ot it.
got this trick from someone on this forum and it works everytime!!
Good luck!
Earl
Don Plumley 06-06-2006 09:58 AM
There are many techniques for removing dust caps. I used a large drift punch angled from the inside of the car out (if that makes sense) on the outer ridge of the cap, hit it hard and kept rotating the rotor.
B D 06-06-2006 10:08 AM
The hammer technique works good sometimes it may need to go in a little before comming off. Keep going around the dust cap prying the cap up a little at a time.
bkreigsr 06-06-2006 11:05 AM
the tech manual shows how to lay a bf screwdriver across the hub, then use that blade as a bottom for your lever, which is another bf screwdriver. work your way around the cap. use the hammer as little as possible
Bill K
Por_sha911 06-06-2006 07:42 PM
This was recently discussed. There is an excellent suggestion using a muffler clamp. Do a search.
tswaney 06-06-2006 08:06 PM
Muffler clamp method worked beautifully for me!
http://forums.pelicanparts.com/showthread.php?threadid=183349&highlight=wheel+bea ring+cap+removal
edit: not sure on the year range for which this method is appropriate!
SP2 06-06-2006 11:58 PM
I just used a ball peen hammer. Hit it at an angle, from in to out, and rotate the hub as you do it. It starts to easily wiggle out. Use some channel locks to pull it out, or I just used my hand. It's easy!
Wil Ferch 06-07-2006 05:46 PM
the link from tswaney is the absolute bees knees....
simple...works....and no "hammering" around things like bearings that don't like this kind of rough treatment.....
- Wil
Chris Holcombe 06-08-2006 08:21 AM
I just did this on a car that never had the dust caps off before. After much hammering, prying, and swearing on these milspec items I used the method in the link above and it worked like a charm. Get a 2" muffler clamp and a pry bar.
911Gal 06-08-2006 08:21 AM
Still trying the clamp method. Nothing else works. This is probably the first time in 20 years this has been removed and it is definitely seized in place. Any other suggestions. Am I the only one with this many problems? My husband says I'm cursed. Beginning to think he's right.:confused:
Gunter 06-08-2006 09:02 AM
I manage very well with large channel lock pliers: grab it perpendicular and wiggle up and down. Muffler clamp works great too.
These caps were off before for repacking grease, otherwise the bearings would have burned in 20 years without it.
Consider doing the whole front like bearings, rotors, caliper-rebuild.
That way you know that all is well up front.
The Bentley manual has a good write-up and pictures for the procedure.
Adjust the correct play in the taper-roller bearings with the split-nut (The one with the Allen bolt) according to the specs.
911Gal 06-11-2006 07:32 AM
Thanks for all your help. For me the clamp and a 12" pry bar did the trick. After the cap came off everything else was easy.
