Front Rotor
Trying to replace rotors on front wheels. According to service records this will be the first time. I changed rears with very little problem. Moved to front and cannot remove the dust cap. Any suggestions?
Stephanie '86 911 Carrera Targa |
911Gal,
May sound funny but use two hammers. Place the claw end of one against the dust cap and use the other to hammer the hammer end ot it. got this trick from someone on this forum and it works everytime!! Good luck! Earl
78 SC Coupe 93 RSA (Gone) |
There are many techniques for removing dust caps. I used a large drift punch angled from the inside of the car out (if that makes sense) on the outer ridge of the cap, hit it hard and kept rotating the rotor.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
The hammer technique works good sometimes it may need to go in a little before comming off. Keep going around the dust cap prying the cap up a little at a time.
68 911L |
cycling has-been
the tech manual shows how to lay a bf screwdriver across the hub, then use that blade as a bottom for your lever, which is another bf screwdriver. work your way around the cap. use the hammer as little as possible
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Make Bruins Great Again
This was recently discussed. There is an excellent suggestion using a muffler clamp. Do a search.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Muffler clamp method worked beautifully for me!
Removal of Dust Cap on Frt wheels bearings edit: not sure on the year range for which this method is appropriate!
Tom '71 911 T Targa (Sold )
I just used a ball peen hammer. Hit it at an angle, from in to out, and rotate the hub as you do it. It starts to easily wiggle out. Use some channel locks to pull it out, or I just used my hand. It's easy!
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
the link from tswaney is the absolute bees knees....
simple...works....and no "hammering" around things like bearings that don't like this kind of rough treatment..... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
I just did this on a car that never had the dust caps off before. After much hammering, prying, and swearing on these milspec items I used the method in the link above and it worked like a charm. Get a 2" muffler clamp and a pry bar.
Still trying the clamp method. Nothing else works. This is probably the first time in 20 years this has been removed and it is definitely seized in place. Any other suggestions. Am I the only one with this many problems? My husband says I'm cursed. Beginning to think he's right.
Somatic Negative Optimist
I manage very well with large channel lock pliers: grab it perpendicular and wiggle up and down. Muffler clamp works great too.
These caps were off before for repacking grease, otherwise the bearings would have burned in 20 years without it. Consider doing the whole front like bearings, rotors, caliper-rebuild. That way you know that all is well up front. The Bentley manual has a good write-up and pictures for the procedure. Adjust the correct play in the taper-roller bearings with the split-nut (The one with the Allen bolt) according to the specs.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Thanks for all your help. For me the clamp and a 12" pry bar did the trick. After the cap came off everything else was easy.
