How do I wire the tach and the temp/press gauge?
It's time to put the gauges back in, but I don't remember where all the wires go :confused:
Maybe someone can help me by matching the numbers and letters in the pictures below? Thanks :) Temperature and pressure gauge: http://forums.pelicanparts.com/uploa...1149817461.jpg http://forums.pelicanparts.com/uploa...1149817513.jpg Tach: http://forums.pelicanparts.com/uploa...1149817551.jpg http://forums.pelicanparts.com/uploa...1149817574.jpg |
Let this be a lesson. Always mark the wires when you pull them. I use masking tape with black magic markers. You need to look at a wiring diagram for your car. You did not say what year you have but I assume its a 77 from your signature. Pelican may have a wiring diagram in its tech section. Check it out. The color codes will tell you what wires go where. I would help more but I do not have a 77 wiring diagram. Anything newer than a 75 is too new for me. Good Luck.
Ove,
I would have thought that my 1975 had the same wiring, but maybe it's just hard to see. I have only looked at my temp/oil and here is what I am sure of: 1-B 2-? 3-J 4-? 5-E 6-D 7-H 8-I 9-G 10-BLANK 11-C I can't see anything that looks like 2 or 4. My #2 is a bulb, with 2 wires going to it, a green with white hash marks and a red with black hash marks. My #4 is also a bulb with 5 wires going to it: 2 blue wires and 3 red with black hash marks. Hope this helps. |
Rex,
Thanks, I really appreciate your help :) I will figure out the bulb wires #2 and #4. What's important is the other connections. |
I'll get the tack wiring for you tonight if someone else doesn't beat me to it - of course you'll be asleep by then (time zone difference).
Now for the tach - our tachs are different. I have 5 holes across the top like yours, but I have 4 terminals across the bottom that are all in a row - yours are staggered. Here is what matches:
A-1 H-2 F-3 G-4 B-5 The above are exact matches to what I have. I'm not sure about your 6, 7, and 8. I have, from left to right, in a single row, the following: Black with purple hash (your E) Red with black hash and red with white and blue stripe (your C) 2 brown wires (your D) The last connector is blank. Best of Luck. |
Rex,
I have a spare tach which is just like yours (from the US, bought on eBay). Maybe I'll use it instead. I installed the temp/pressure gauge tonight. Thanks for all your help :) |
HI your RPM counter is out of a 3.2 and the wiring terminals are No 5 live/ignition, No 6 earth, TD black/purple, taken from a 85 diagram.
regards mike |
Ove, if your wiring is the same as my 78SC, I am happy to pull my gauges and take pictures for you?
where does the green wire go?
All, please see the picture at the start of this thread.. the wire marked A (green)
anyone have a clue where it goes? i have a 1977 Carrera 3.0 that i am putting back together... i can't find the green wire on the diagreams thanks Tom |
| All times are GMT -8. The time now is 10:52 PM. |
