Brorag
how to apply whale tail gasket?
I'm redoing my '87 911 and am about to reinstall the whale tail.
2 911's cross country, the sequel here's the problem: ![]()
jd Last edited by Brorag; 04-28-2008 at 03:50 PM.. |
Dog-faced pony soldier
I just put the tail on the decklid loosely and slid the thing in underneath. The adhesive isn't all THAT sticky. Once the thing was in place, I tightened all the bolts down and "squooshed" it in there. That, plus heat/time hold the gasket in place nicely.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Hire an octopus to help you hold it in place while you tighten it down. ! Or use the black 3M product so it won't show up so bad.
I applied it on a cool evening with relatively high humidity. I imagine this helped to make the adhesive less sticky.
+1 on the octopus thing. You need at least 8 hands to get that thing in. Not a hard job, but a bit frustrating at times. Be patient - you'll get it in there eventually. It's an exercise in persistence.
Just did that last week. Used 3M moulding tape (double sided) on the tail lip first and then placed the rubber around the tail and pressed down until held in place. Then mounted the tail to the lid. Of course, I cleaned everything first. Came out nice.
84 Targa (Regina) Ruby Red |
You use pop rivets. I bought a pop rivet gun and learned how to install aluminum (not steel!) pop rivets specifically for this job, and it has come in handy ever since.
Brorag
yo, rusnak
Rusnak--how long has it been on there?
Island breeze--nice job.................... Last edited by Brorag; 04-28-2008 at 04:42 PM.. |
Brorag,
I did this almost two years ago. I bought the decklid, tail, everything from another Pelican member, and had it stripped and re-painted. I installed the factory gasket, factory decklid badge, and factory decklid strut on the right hand side. Funny, the gasket didn't give me any problems at all. I'd say definitely degrease the surface of the tail, use a new gasket, and install aluminum pop rivets. It'll stay on there rock solid. I put the seam at the bottom at the dead center. I glued the gasket ends together with super glue, and the rest using the adhesive backing that the gasket came with. |
Not sure if this will help, but here is a repair I did:
Rear Spoiler Base/3rd Brake Light Repair with pix
'87 Cab |
