89 Carrera Idle Stumble
Hey....new to the 911 world here...big change from my 914!
Was wondering if anyone could give me a quick tip on what could be causing a slight stumble when the motor is warm. Car has 120K on it...totally stock except for Andial chip and sport exhaust. Runs otherwise excellent, starts right up, etc., but has stumble at idle, barely noticeable on tach, but annoying when waiting for a light to turn green. Any advice? Thanks! Mike
VOPO '74 2.0 |
Ignition wires.
Joe |
Do your basic tune up stuff first if the car is new to you. Valve adjust, plugs, air filter, oil change, fuel filter, blah blah blah. Cap, rotor and wires if you're feeling expansive. That may take care of itl If not you'll have a solid base to work from. Good luck and congrats. Also, don't bother asking for help again until you post a pic.
![]() ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Good luck. I've had the same problem for 8 years and have been unable to fix it. I've tried all the mentioned items with no success. New injectors, O2 sensor, etc. didn't make any difference either. I swapped back to the stock chip and even tried a different one (have a Wong chip with SSIs now) without success.
After a while, I just got used to it so I haven't tried anything new in a long time. It idles like a V8 with a big cam. I think this is a common issue with 3.2s. If anyone has any good ideas, please pass them on.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
Check the idle control valve. They need cleaning once in a while
Michael PCA-INWR 356 Reg. Early S Reg. R Gruppe PNW |
UFLYICU
CO mixture.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Loose intake manifolds with sucked in manifold gaskets.
Pretty common on 3.2's. Joe |
There's an easy way to find out if your stock Beru ignition wires are any good. Just spray some windex on your distributor cap wires at idle and see if it misses.
Joe |
UFLYICU
Also, you can turn off all the lights in the garage and peek under the hood. If the wires are arcing, you see it. Have someone rev it.
In my 84 carrera I had more of a revving at idle (up/down) 200 rpm which might be different from your issue, but after doing all the usual tune ups (especially fuel filter) I found that it seemed to be triggered by use of the Cruise control.... Even if I flicked it on by accident or actually used it on the highway, once I was back in the city it would rev (not hunt) at idle...
I didn't do anything to the cruise control other than not use it since, no problem with revving since... Maybe unrelated but I thought I'd share it. Gremlins are everywhere in these cars.
_______________________ '85 Black ROW Coupe (trying to put back together) '88 Blue 951 (sold) '84 Blue couple (sold) |
If my mixture is set too rich it will definitly stumble off idle.
Joe 86 3.2 |
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Mixture often causes idle problems. Have your wrench check it and adjust, if necessary.
1984 Targa |
UFLYICU
I said mixture. I said it first.
