-   -   msd blaster coil problem (http://forums.pelicanparts.com/porsche-911-technical-forum/287908-msd-blaster-coil-problem.html)
dynevahn 06-12-2006 10:16 AM
anyone else have a problem get the wire from the distributor to the coil? it just doesnt want to stay attach on the inside. Im using magnecor wires. Anyone else had this prob?
Early_S_Man 06-12-2006 10:41 AM
Is this the High-Vibration epoxy-filled, or the slightly larger oil-filled one?
You might try one of two strategies:
1. Loosen the omega-shaped coil clamp/bracket and slip the coil down a bit towards the distributor.
2. Get the relocation coil bracket used on engines with factory A/C ... it moved the coil downwards about 3" - 4" on the slant of the fan housing to give more clearance for the A/C condenser coils hanging under the deck lid.
