WEVO Banana Arm EZ PINS?
Has anyone used these pins in the rear suspension? What is your opininion? I have a number of WEVO parts and am very satisified. I have done a search of PP but have not found any information.
Thanks DanB
Dan |
we've installed a few and are quite happy with the results. It saves the shop and client hours of time when replacing a control arm or inner bushings w/o the need to remove the engine and trans.
The earlier torsion tubes don't have indentations to clear the oe bolts when you go to remove them with motor/trans still in the car
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Would someone post a pic please. I'm not sure what pins you are talking about.
Keith Lally 85 911 Blue Coupe - gone 84 911 Silver Coupe - gone |
http://www.smartracing.net/pdfcat/srp2006_rearaxle.pdf Look at the bottom of page 64.
Dan |
Exactly which years don't have the torsion tube indentations? Would my '77 benefit from the pins?
77 has the indents- i think 73 is the first year with the indentations if my grey matter is working right, and again these are only useful if you need to remove the control arms from the car
Seems worthwhile if you've got an early 911 racecar
Sherwood |
the indentation is in the torsion tube, not the mounts
I installed these during my last torsion bar/bushing upgrade. My '71 does not have the indentation on the torsion tube so I had to drop the motor and trans.
Anyway, they are *slightly* larger in diameter than the original bolts and would not fit through my Elephant Racing monoballs. They did however, work with my Racer's Edge monoballs. Of course, the Elephant monoballs worked fine with the stock bolts, it seems just that one odd combination did not work.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
Thanks for the correction. Okay, I know the early control arm bolts were installed with the bolt head on the inside. I thought the later cars had the bolt heads on the outboard side, but I guess they were oriented the same but the indent on the torsion tube allowed removal. How about just reinstalling the bolt with the head facing toward the outside? Are these Smart Racing pins still needed in this case? Sherwood |
Hey Sherwood-
If I can butt in- Here's a good picture showing the indentations. ![]() Your previous assumption was correct. The later bolts were installed outside in. You can try that with the early cars but without that indentation you can't get a straight shot.
EZ Pins
Sherwood,
If I follow this, than are you saying without the indentations on the torsion the bolts will not be removable without an engine drop even if the arm bolts are facing outside in? Do you think the ez pins will not work for an early car without the indentations?
Dan |
you won't be able to put the bolts from the outside - in if the tube has no indentation
that is one of the reasons why the ez pins were invented
I will snap a picture of my car, I have a set of the EZ pins.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
Oh here, I found an indirect picture on my computer.
They are flat on one side and just the right lenght to get the bolt on and thats it. -Britain
Here is another indirect shot that might help.
-Britain
