901 torque question
Can anyone confirm the torque setting on the elastic screw (expansion screw, part number 901.332.275.01) that holds on the link flange for the differential gear on a 901 gearbox? If I'm reading the manual for the part correctly, it lists a range of 32.6 to 36.2 lb.ft, but I'm not sure. This is my first gearbox overhaul/go-over. Thanks for any help on this and thanks for all the posts that got me up to this point (gearbox now back together with new syncros on first, second, and third and new intermediate plate bearings). Tom
Old 06-10-2006, 03:11 PM
randywebb's Avatar
post the year - I have the spec. for a 1971 type 911 box
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-10-2006, 04:48 PM
Thanks for your reply. I'm not sure if I know the year as it is a gearbox I purchased for my 68 SWB, as it had a four speed in it (or rather, with it, as I bought the car basically in boxes). I suspect it is a 1966 because of some of the numbers on it but I'm open to suggestions. Stamped on the gearbox include the numbers: 28/66, 103124, and 901/02. As expected, when I removed the "elastic screws" they did not have the little nipples on them, as would have been the case with a simplified differential (prone to failure as Grady has pointed out). Thanks for any advice on the torque setting on these bolts. Tom
Old 06-11-2006, 02:34 PM
Any ideas out there? Thanks, Tom
Old 06-13-2006, 01:48 PM
randywebb's Avatar
32 can't be too far off
Old 06-13-2006, 02:48 PM
