Odometer not working
Before I tear things apart I wanted to know if anyone has suggestions on what the problem is.
My speedometer works fine, however the odometer is not racking up my miles. I have driven about 60 miles and it only went about 1/10th of a mile?
any help is appreciated.
Old 06-13-2006, 11:38 AM
Huh Huh is offline
Which car? Get the Wayne Dempsey: 101 Projects for your Porsche 911. It gives you the fix. It is probably the big toothed gear that is turned by the electrical wormgear motor. That was what was wrong with mine. It is a very common problem. You need to take it apart to verify which part then order it through Pelican parts.
'94 VW Jetta
'85 VW Scirocco
'81 911 SC coupe Euro
'67 VW Bug
Old 06-13-2006, 11:43 AM
I always forget to list what I have.
'76 911 915 trans 3.0ltr
Thanks Huh, I have the book and will check it out.
Old 06-13-2006, 12:33 PM
If its the gear, you will know it the minute you pull the speedo apart...the gear usually will just crumble to pieces. I bought a replacement gear ahead of time and i replaced the gear and had the speedo back in and working within an hour. Just need to be careful when you remove the speedo documenting the wiring configuration, etc. If you take your time you should be fine.
86 911 Targa
Old 06-13-2006, 12:50 PM
khamul02's Avatar
Turbo-Mag throw you car in your sig. It really helps other people help you.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 06-13-2006, 01:43 PM
Anyone know the part number for the odometer gear. I have a 82 SC and need to fix mine but am having a heck of a time finding it from our host
1982 SC
Old 06-13-2006, 02:17 PM
I'm new to this, how do I put my car in my sig?
Old 06-13-2006, 02:40 PM
Driving member
jester911's Avatar
I don't think the gear is for sale here. Do a search for something like odometer. com . They sell the gears you need.
Or send it to a speedo shop. Chances are with the age of these gauges, they need refurbishing anyway.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 06-13-2006, 02:47 PM
Driving member
jester911's Avatar
Go to the top of the page and look for the user cp button.
Click on it and follow the links.
Jerry
Old 06-13-2006, 02:48 PM
defcon65's Avatar
Try North Hollywood Odometer, they have all the parts and service the VDO gauges. They have a website.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 06-13-2006, 02:49 PM
scottb's Avatar
www.odometergears.com
www.speedometergears.com
1984 Targa
Old 06-13-2006, 03:05 PM
