Ignition switch shut off?
This is on a 1980 SC that starts and runs fine but will not shut off with the ignition switch. When I turn the switch to off, the gauges, accessories, etc; go off and the alt. light comes on, like in the run position but the engine does not miss a beat. also, it only does this after a drive and up to temperature. It starts up and shuts off fine with the switch when cold. Any ideas? Thanks.
Old 06-12-2006, 08:44 AM
Now, it stays running hot or cold. What could keep the engine running when the switch is off when everything else shuts off with the switch like it should?
Old 06-14-2006, 04:03 PM
It's a stock ignition correct?
MSD has a diode fix in their instructions.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-14-2006, 04:34 PM
walt's Avatar
Odd, but this happened to me last weekend. Can't explain why but I either pulled the electric window relay or the cruise control relay and the car starts and stops fine now. I am really perplexed whats going on here including why the electric windows still operate w/o the relay. I may have some wiring out of place from a previous owner. This might be a "one of" situation and of no help to you.
Walt
82SC 3.0
81SC 3.6
Old 06-14-2006, 04:58 PM
Stock ignition. I know the turbos have a diode at the generator light for the ignition delay relay probably to prevent this kind of problem. I am not sure though.
Old 06-14-2006, 08:28 PM
