bonaturtle's Avatar
Send a message via ICQ to bonaturtle Send a message via AIM to bonaturtle Send a message via Yahoo to bonaturtle
Easiest way to replace window switch...
my driver's side window switch is dead, already have a new one in hand. I was able to pop out the current one, but didn't disconnect anything.
Found the diagrams through search, although for an 84, I have an 88. Easiest way to do this, and will I electrocute myself
Sean
1988 911 Coupe Blk/Linen
1992 Mercedes-Benz 190 2.3
1999 Honda Accord LX
2003 Kymco People 50 (city killer)
Old 06-13-2006, 11:19 AM
Rick964's Avatar
You won't electrocute yourself, but you could always disconnect the battery if you want to. If there is enough wire slack to move them one at a time from switch to switch that would be the best, otherwise write down each wire color and the terminal number it goes, a diagram would not hurt nor would taking a picture with a digital camera before you disconnect anything.
Old 06-13-2006, 11:31 AM
bonaturtle's Avatar
they all looked the same color, but i didn't look that long, do they just pop off?
Sean
Old 06-13-2006, 11:36 AM
Super_Dave_D's Avatar
2nd the battery disconnect. Get out a pen and paper and draw!!
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
bonaturtle's Avatar
not sure if i want to disconnect the battery, i'm handy, but not that handy.
Sean
Old 06-13-2006, 11:42 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
are the wires hot if the key isnt in the ignition and turned? or is it a connect the ground kinda thing where its hot all the time? i swapped mine out without disconnecting a thing. I guess you could get a voltmeter and test the wires to see if any are hot.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 06-13-2006, 11:57 AM
aftermath's Avatar
omg, its 12 volt swap one wire at a time, if your concerned disconnect the battery, if your not handy enough for that you better go to a shop and spend some money. Dont mind me Im grumpy today.
theamsoilguy@hotmail.com
Old 06-13-2006, 12:03 PM
Friend of Warren
You don't need to disconnect the battery, but you really need to learn how to do so in case of an emergency. There are several different colored wires so draw a diagram.
Kurt V
Old 06-13-2006, 12:07 PM
pmajka's Avatar
dumb Q...do i need to remove the door panel to install the new switch, or is it Pop out, pop in?
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 06-13-2006, 12:44 PM
You can pop them in and out. Draw a diagram, then replace one at a time.
Then only snag you could hit is while you are pulling the switch out, the slack could not be enough and the wires could pull off the post.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 06-13-2006, 12:58 PM
Flyer88's Avatar
Put feet in bucket of water, turn on ignition switch and remove wires. Sorry I must be grumpy too. Actually I just did this 2 weeks ago - just remove one wire at a time and install on new switch. If it takes more than 2 minutes you are doing something wrong.
Bill
87 911 Targa
06 Toyota Sequoia
Old 06-13-2006, 12:59 PM
i didn't know there was a hard way.
206 637 4071
Old 06-13-2006, 01:20 PM
Make Bruins Great Again
Por_sha911's Avatar
If you don't want to learn how to disconnect a battery, I hope you got lots of money cause things get pretty expensive when you don't do it yourself.
Joe
Old 06-13-2006, 06:07 PM
bonaturtle's Avatar
i'm not ignorant, just not familiar with this one yet, i do a lot of stuff myself that I can get my hands around.
Sean
Old 06-14-2006, 07:19 AM
emac's Avatar
Sean
Battery is located in front of car on the drivers side. Knowing this you should be able to disconnect it since you do a lot of stuff yourself. If this doesnt help get a pair of bolt cutters so you can cut the wires.
Ernie 81 SC
Old 06-14-2006, 09:32 AM
no need to disconnect the battery. no power there unless the key is on.
206 637 4071
Old 06-14-2006, 09:45 AM
Por_sha911's Avatar
Get Wayne's 101 Projects book and Bentley's Manual. They are worth their weight in gold.
Joe
Old 06-14-2006, 08:26 PM
