VinnyC's Avatar
Why is posting photos here SO difficult!!
Why is it so difficult to post photos on Pelican!!
Each time I try to post photos I get the following message:
"Content-Type: text/html; charset=ISO-8859-1"
No matter what size, file type or shape.
Someone please explain why this is such a problem for me.
Old 05-31-2006, 02:21 PM
Driving member
jester911's Avatar
It shouldn't be. Just go to the link Click here to Upload a Photo.. Then hit the browze button in the window that pops up. Choose the pic you want from your files and click it. You should see a link to your pic in the popup window.
Then hit upload in the same window. If the pic is too big it won't load. Otherwise your good to go.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 05-31-2006, 02:29 PM
VinnyC's Avatar
Not for me. No matter what size or file type I make the photo it won't upload.
Am I the only one this happens to?
Old 05-31-2006, 02:44 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
yes
Marc
Old 05-31-2006, 02:51 PM
defcon65's Avatar
Check the photo download tips when you post and adjust to a smaller size. I'm challenged to say the least when it comes to computers but was able to post them second try.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 05-31-2006, 02:55 PM
Dan in Pasadena's Avatar
I had trouble with my sizes being too big. Typically making them 75% of their original size fixed it. Also, ad a ".jpg" suffix to your photo file names and it may fix the problem. Worked for me.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 05-31-2006, 03:04 PM
Yes, save your pic files as *.jpg. The board will not recognize a bitmap or any file other than .jpg.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-31-2006, 03:09 PM
khamul02's Avatar
another thing, if on a Mac this BBS may not see the file extensions. And Now even though the message says images must be under 2 megs I believe the limit is now 100K.
So make sure you have a .jpg or .gif or (I wouldn't try due to file size) .bmp & keep um under 100,000 bytes.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 05-31-2006, 08:45 PM
Detached Member
Hugh R's Avatar
spaces in picture names can be a problem. for other sites, I use photobucket.com and link to the images.
Hugh
Old 05-31-2006, 08:48 PM
jwetering's Avatar
IIRC the program doesn't like spaces in the file names either. The image below is 876 KB and was uploaded from my mac.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 05-31-2006, 08:50 PM
Michael Delaney wanna-be
Netspeed's Avatar
VinnyC....you're not the only one. I have the exact same problem. I've done all the resizing and no-space file name recommendations...all with no luck. I tried from work today and once it worked and then another time it didn't. Strange problem.
Wayne is working on getting it fixed
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 05-31-2006, 09:04 PM
Adrenaline Junkie
Hayabusa's Avatar
Vinny, I think it is temperamental.
Try typing a few of your words into your script box first before you go to upload/browse for pictures.
It's squirrely, I tell ya!
Old 05-31-2006, 09:05 PM
khamul02's Avatar
check your images. open your image. Right click it and select properties. The image above is roughly 63K well under the 100K mark.
Tom Hutchinson
Old 05-31-2006, 09:17 PM
Oracle's Avatar
I had the same problem yesterday, I tried a few minutes later and worked fine! (same picture)
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 05-31-2006, 10:37 PM
randywebb's Avatar
Problems:
1. file size too big
2. resolution too high (hit Ctl-R in Irfanview)
3. Name has spaces
4. Name is too long
5. Not a .jpg file
too bad it isn't more user frinedly but there are probably a million pics up already so you can make it work.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-31-2006, 11:23 PM
87coupe's Avatar
That's after imagemagik chomped on the original 876k picture.
ßrandon
Old 06-01-2006, 02:38 AM
RETIRED
Joe Bob's Avatar
If you don't have an image program....most email clients will auto reduce for ease of transfer...send them to yourself and repost.
2012 ML350 3.0 Turbo Diesel
Old 06-01-2006, 04:21 AM
ozz ozz is offline
ozz's Avatar
I've had plenty of problems as well using images sized to 800x600 as recommended, under the 100k limit in size, 8.3 file names - no spaces or special characters, .jpg and still got errors....
Gary Osborne
Chardon, Ohio
___________
74 911 IROC
98 Panoz GTWC
Old 06-01-2006, 05:48 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Is my memory failing me, but didn't the bbs re-size photos in the past ??
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-01-2006, 05:59 AM
Netspeed's Avatar
I'm no computer whiz but I think that ISO-8859-1 message has something to do with XML validation. The stuff we send to post at Pelican has to be interpreted correctly (different computer platforms and languages).
88 Carrera Cab
Old 06-01-2006, 06:04 AM
