304065's Avatar
Limited Slip Friction Discs
For a 901 ZF limited slip, how often should the friction discs be changed? This is a full race application, 155 HP, about 30 hours of operation per year.
Is this a complex operation? Does it entail setting the backlash? Are the parts available or NLA?
Thanks in advance. Geary, I would particularly appreciate your expertise here.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-07-2006, 01:02 PM
Hi John:
I'm not Paul, but I've done a few of these over the years,...
FWIW,....I measure the breakaway torque of the LSD every year and track its wear & functionality. When its at the end of the tolerance range, I simply pull the thing out the side cover, remove the ring gear and take it apart to replace the friction discs.
Its pretty easy to do and one simply must keep track of the order the plates (fiber & steel plates) to maintain the same locking factor and replace the ring gear bolts each time.
Either Paul or the Dealer can get you plates,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-07-2006, 01:19 PM
DG624's Avatar
Steve, is the 915 similar to the 901? Was the LSD standard or optional?
Old 06-07-2006, 01:47 PM
304065's Avatar
Ahh, no less a personality than the good Dr. Weiner to the rescue!
I suppose that in the factory shop manual there is a procedure for measuring the limit torque. I'll do some research and report back.
'11 was $9.04 each, 6 req'd
'00 $21.05 x2
'21, or '22 or '23 can't find in the Pelican system.
'81 R65
Old 06-07-2006, 06:10 PM
304065's Avatar
The 915 lsd has one common part, but its discs carry a 917 p/n (nobody get excited, 917's had 920 part numbers!
'81 R65
Old 06-07-2006, 06:14 PM
Hey John:
Looks like Porsche has discontinued those friction discs in all 3 thicknesses. Those numbers are not in their current pricing. I haven't bought any since my last order,......
Call Paul Guard.
The book has the breakaway specs for 40%, 50%, & 80% lockups. If you cannot find that, drop me a direct e-mail and I'll get those for you.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-07-2006, 06:49 PM
The '21 part number was superceded to 951-332-551-00.
Old 06-07-2006, 11:49 PM
Geary's Avatar
Hi John
The price for friction discs has increased to (gasp) $59 apiece.
Paul
Old 06-08-2006, 08:16 AM
304065's Avatar
Thanks Paul. Where most guys freak out at the prospect of paying $59 each for the discs, I'm just happy they aren't NLA. It comes from restoring a '66.
So last evening I dug out the workshop manual and noted with interest the factory procedure for testing the lockup percentage. With the carrier in a vise and a couple of special tools affixed, you apply a torque wrench and note the figure in meter-kiloponds.
Here's my question: is there a "shade-tree" method for doing the same thing without disassembly of the transaxle? Can I jack up one rear wheel and apply my torque wrench to the wheel hub castle nut and note the breakaway torque? Will that be accurate enough to know a worn-out diff from a good one?
Thank you gentlemen in advance for any advice on this matter.
'81 R65
Old 06-13-2006, 06:57 AM
Geary's Avatar
I imagine this would be a reasonably accurate test.
Old 06-13-2006, 02:32 PM
goldgunner's Avatar
Question for you experts:
I recently had my 915 rebuilt by a local Porsche shop that has 'done hundreds' over the years.
I'm sure my 80SC has never had a transmission rebuild: had the usual first gear problem.
According to the shop the bearings were good - is this expected and usual on a 25 year old transmission?
The transmission turned out to be a factory LSD - but I'm looking at the itemized work ticket and no LSD components / plates appear to have been replaced. Is it probable these were worn and should have been replaced?
Thanks,
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 06-13-2006, 03:17 PM
Irrationally exuberant
ChrisBennet's Avatar
I think you meant 917 parts carried a 912 part number.
There was an article in the May issue of Excellence magazine called "The Cheap Seats! A Bargain 912 Racer". The owner of the 912 got a hard to find factory racing oil cooler for it from Carl Thomson (noted Porsche race car restorer and owner of his own 917). "Carl joked that we 912 owners need to stick together."
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-13-2006, 04:39 PM
beamonk's Avatar
Send a message via AIM to beamonk
I was wondering how to measure wear on a 915lsd. We took mine apart and my wrench said they were beautiful and to leave them alone. We haven't gone through the tranny yet, but I was wondering if we should mic them or get new ones to increase the locking % as this will be a driven to the track track car.
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 06-13-2006, 06:04 PM
benjoys02's Avatar
hi everyone,
i have an '81 sc which i think has an LSD. i raised the rear of the car earlier today and manually rotated the driver side rear tire forward and the passenger side moved in the same direction with no hesitation. just to confirm that the car has LSD, is there a serial number that would indicate such?
thanks!
benji
Old 06-13-2006, 06:30 PM
lally911's Avatar
The 12 stamped between the 915/73 and the 74F indicates factory LSD install. Location for this number is on the bottom of the tranny near the drain plug.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 06-13-2006, 07:34 PM
benjoys02's Avatar
thanks! i'll check my car again tomorrow.
benji
Old 06-13-2006, 09:04 PM
[B] Here's my question: is there a "shade-tree" method for doing the same thing without disassembly of the transaxle? Can I jack up one rear wheel and apply my torque wrench to the wheel hub castle nut and note the breakaway torque? Will that be accurate enough to know a worn-out diff from a good one?
Hi John:
You betcha there is,.... With the rear end of car up on jackstands, pull the CV's off the axle flanges on the transmission.
Make a pair of 2"x 6" aluminum (or steel) bars. Drill a hole in the middle and install a 10mm bolt & nut. Drill two holes near the edges that line up with two of the CV joint holes on opposite sides so you can bolt this up to each axle flange on each side of the differential housing. You'll need some short CV bolts,...
Now, while holding one side of the diff with a socket and breaker bar, attach your torque wrench to the opposite side and slowly pull up the wrench and observe the torque setting when it moves.
Works great!!!
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-13-2006, 11:40 PM
Fuchs w h o r e
I don't see why this wouldn't work. Have you got some comments, Steve? Paul?
Old 06-14-2006, 12:43 AM
304065's Avatar
Chris, truth be told, I originally wrote 902, because I was thinking 912, before realizing that I really DID mean 912. In any case, I went to Grady's excellent compilation and realized that the 917's box had a 920 part number. All in a day's work.
'81 R65
Old 06-14-2006, 05:33 AM
Geary's Avatar
These friction discs are the most common disc in the industry, used in the LSDs of many marques. They have been sold under a variety of part numbers (although actual thickness may vary slightly), including part #917 332 522 11.
Old 06-14-2006, 09:38 AM
