Coupler bushing failure
I was down shifting to 4th and heard a snap, the next thing I knew all the gears were in different places and reverse was getting "knicked" too often. Having read a bit about it I figured on the shift coupler bushing failure. Here's the results. At least it's a cheap fix. I plan on replacing and servicing everything else while I'm in there. Any hints on things to change or do. Ball cup, coupler bushings etc.
Mike.
1972 911T, non-sunroof coupe.
Old 06-17-2006, 07:12 PM
Sorry too quick on the submit button. Heres the pics.
Mike.
Old 06-17-2006, 07:14 PM
Immature Member
dentist90's Avatar
Well, you got your money's worth out of that bushing! You're on the right track.. change all the rubber/nylon in there. Don't forget the shift rod sleeve (O-shaped bushing the shift rod slides/rotates in) under shifter housing. I think you're gonna notice a huge change in the feel of your shifter when you're done, judging by the wear on that coupler.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-17-2006, 07:39 PM
