-   -   What do auto heat flapper boxes look like? (http://forums.pelicanparts.com/porsche-911-technical-forum/289036-what-do-auto-heat-flapper-boxes-look-like.html)
ROWSC 06-18-2006 12:02 PM
I see several other people have the same question, but I haven't been able to find a thread. Are they any different than regular flapper boxes with the exception that they have the sensor installed?
Thanks and Happy Father's Day to everyone.
Rich
Oh Haha 06-18-2006 01:03 PM
The flapper boxes are the same. The auto-heat sensor is actually located between the sunvisors.
The boxes are located under the car.
ROWSC 06-18-2006 04:26 PM
There is also a sensor that is riveted to the driver's side flapper box. It routes under the carpet to the heater control panel between the seats. Looking at the PET, it appears that this sensor isn't even riveted to the flapper box but to a seperate extension tube.
Rich
imcarthur 06-18-2006 06:01 PM
http://forums.pelicanparts.com/uploa...1150678832.jpg
imcarthur 06-18-2006 06:08 PM
The pic above is from an Autoheat car. As you turn the control, the servo pulls a cable which pulls another cable to open/close the valve. The HE temp sensor is just that. The cockpit temp sensor is between the visors or on the dash depending upon year & car type. I believe the flappers for manual & auto are the same.
Ian
