Back in New England!
Just a quick question.
I found a screw in my right rear tire. Fortunately it is between the treads and not in the sidewall. It appears to be penetrating the tire in the straight down direction. My tires are ZR rated with less than 2K on them and I'm looking to preserve the as much strength as I can in the tire. So should I have it patched from the inside (which is what I think I should do) or should I have it plugged?
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Detached Member
From the inside, always. Plugs and pull out.
Hugh |
Hmmmm..Ok, I'm not a tire manufacturer, (so i can't say absolutley) but I would take it to a good tire place that sells the tire brand you have. They might say "No", based on the ZR rating. Then it's up to you.
Inside repair is the prefered method of sealing it.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Patch it - only way to go. I've had a number of Z rated tires patched. Plugs are only good if you are stuck in the middle of nowhere. I carry them when I go on long trips.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Patch the tire and you will be fine.
Eric 1978 spec 911 1998 C2S |
I thought plugging wasn't allowed anymore? At least that's what the tire guy told me here in CA a couple years ago.
I would patch anyways.
1989 Carrera 3.2 Silver Anniversary Edition 2007 BMW 750Li 2005 Honda Odyssey EX-L http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html |
Automotive Monomaniac
Patch the tire from the inside.
If it can be easily patched (just a small puncture), it is still Z-rated.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
This was on an old thread...
IIRC, a patch from the inside means you can still use the tire, but it loses its speed rating. Plugs are not a well regarded repair technique any more... Obviously the above might not hold true for a tiny pinhole or something, but...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Whether or not the tire retains its speed rating varies from manufacturer to manufacturer. For liability reasons (they aren't going to inspect every flat tire), many just throw and in the towel and tell you to buy a brand-new tire.
Use your judgement. As long as the belt isn't cut (most nails and screws don't cut the belt), the tire is still perfect. My best top speed run was done on two patched tires without any worries. (Kinda related subject... can aircraft tires be patched? Does the FAA allow it?)
I can't imagine a 747-400 with a brand-new $$$ tire with a slow leak needs to toss it out... maybe?
I'll ask my dad what he would do as well. I think he would replace it, but maybe not. I'd like to know as well.
Dave EDIT: I do know that the tires on his plane do loose air from time to time and we will check pressure and fill if needed, but I don't know what he would do if the tire had a visible nail, staple, etc...
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 06-19-2006 at 10:55 PM.. |
Also, tires are made of plies of belts..each one different and wrapped in different biases. If the screw went thru the carcass, it's thru something or somethings! Point being, speed ratings, like ZR have specific requirements, and you should be aware of what you'll own when it's repaired. Might not be a ZR tire, and that might be fine, but you need to know.
Y'all might enjoy this pic -- I couldn't decide whether to patch it or plug it...
Now in 993 land ...
If you drive at ZR speeds you should replace the tire. It will be okay for 65 mph, but I doubt you drive that all the time, especially if you track the car.
Just do a back of the envelope calculation on how many G's a tire sees, spinning at ZR speeds. I certainly wouldn't want to spin a patch around like that. In Germany, it is illegal to patch high speed tires. Be safe, George |
I just got done plugging a hole in my x5 tires. Maybe its the size, but these tires seem to pick up screws and nails everywhere. Most garages won't plug a tire, why? Because it would force them to not sell you a new one. I would not recommend them for track tires, but as far as being z or higher rated tires, how many actually drive a sustained 120mph for an hour or so? I've never had a plug fail. In fact, I've found tires with worn out nails in them that must of had a few 100 miles on them with no air loss. If it was me, I would plug it until you could get it to shop and then have them remove it and patch from the inside.
Senior Member
That said, there are not many things lying on runways to get stuck in tires. We have "FOD" (foreign object damage) trucks out with magnets that sweep the runways at many airports, keeping damage like this to a minimum.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
