A/c Compressor Upgrade
For people who upgraded the York Compressor to a Sanden or Seiko Seiki rotary compressor, did you use the same size fan belt or did you have to use a difrferent size fan belt? Longer or shorter fan belt?
I |
It has been at least 7 years since I did mine, but I am 99% sure I used the same belt. --DDD
1983 Ruby Red Metallic 911SC 2005.5 Audi A4 2.0T Quattro 1991 Mazda Miata Special Edition British Racing Green www.DDDinMN.wordpress.com |
If you have a factory setup, you can typically use the same belt.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
