-   -   What did I adj. wrong? (http://forums.pelicanparts.com/porsche-911-technical-forum/289886-what-did-i-adj-wrong.html)
emac 06-23-2006 04:30 AM
Hi all
I thought I needed to adjust my clutch, and what I did was adjust the cable thinking this was the right thing to do. Now My pedal is lower than the brake and when I take off in first she slips. Once in second everything is good. I know I did something wrong could someone help.
Thanks in advance.
Patton 06-23-2006 05:17 AM
Do a search for clutch adjustment, I'm sure you'll find plenty. I had the same issue (clutch lower than the break). What I did was have my girlfriend's son left the clutch all the way up and hold it. Then I just adjusted the adjustment nut to snug, stopped at that point. After, pedal height was fine and so was the clutch.
na2ub 06-23-2006 06:46 AM
How, exactly, did you adjust the cable?
Doug
emac 06-23-2006 07:34 AM
Doug
At the end of the cable where it attached to the bracket. There are two nuts one is a lock nut. I went out with it another words I have slack in the cable. I did do a search and printed out some photos.
Zeke 06-23-2006 07:51 AM
Slack, bad word.
We don't want no slackers in the clutch dept.
Patton 06-23-2006 08:29 AM
Listen to the experts emac. na2ub, give me a break.
