ac switch
I just recently had my compressor replaced b/c obvious leak. Everything was fine and then all of a sudden ac just turned offf by itself. Moving fan switch did nothing. Then w/o explanation it turns on again a half hour later. Sometimes it works and sometimes nothing. Any ideas?
mz
Old 07-24-2006, 02:00 PM
Loose electrical connection at the fuse block?
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 07-24-2006, 02:27 PM
Try switching out your A/C relay with a known good relay....I recently had this problem on my front A/C condensor blower fan relay.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 07-24-2006, 02:35 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
my switch went bad
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 07-24-2006, 02:38 PM
which one is relay for ac? Also hoew do you know for sure if switch is bad?
Old 07-25-2006, 03:12 PM
Tell us what year P-car you have and we can help you locate the A/C relay; as far as the switch itself is concerned, you can bypass it and see if the blower comes on. Any time I have an issue like this, I start with the basic stuff...fuses first, then the relay (if applicable), then get out the multimeter and start checking for proper voltage and ground all along the circuit. In this case, if it's not a defective fuse or relay, it COULD be the switch, the blower fan resistor, the AC high/low pressure switch or a wiring problem on one of these components.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 07-25-2006, 04:16 PM
DonMo's Avatar
A wire with a couple of alligator clips will check the switch. Brown is ground. Red is usually power. I would try the mulitmeter process first. If you have no power at the fuse, easy, replace fuse. Power to fuses but fan or compressor doesn't come on, it could be high/low switch, relay or bad switch. My switch was easy to figure out, warm, black and if I moved the wire, it came on.
DonMo
Columbia, SC
"Go Hokies"
Old 07-25-2006, 04:34 PM
year is 87 carrera.
Old 07-26-2006, 09:23 AM
