Cerbin
Guest
Posts: n/a
new engine
Right now i have a 70 911T w/ a 2.2 liter engine and would like to upgrade to a 2.7 or 3.0.. do i have to change the existing mounts? other than the transmission, wht do i have to change?
Old 07-21-1999, 10:32 PM
mikez
Guest
Posts: n/a
Mounts should be the same, you will most likely need to change the flywheel and clutch assembly. The wiring will be a lot different. Especially if you are going from carbs to FI.
Old 07-22-1999, 08:08 AM
