Leaking Targa
All the rain in the mid-Atlantic area this weekend highlighted my leaking Targa problem. I mean like a sieve - in the front, both sides over the vent windows, and right on top of the rear view - as well as the corners in the back. The targa is not original - I'd say less than 5 years old, with very good rubber. The car-side of the seals look ok - not great. Is there an easy fix here ? (besides keeping it in the garage, and/or a cover) If I do seal replacement, what are the chances that the problem goes away? It's under cover now, but if it ever stops raining, it's going to take forever to dry out.
Tim
73 914 Project
80 911 Nice Day Driver
Old 06-26-2006, 10:33 AM
MBEngineering's Avatar
HI i have the set up booklet for the targa roof No' 4562.20 from Porsche, if you PM me your post add i will send you a copy
regards mike
Old 06-26-2006, 11:42 AM
I have a 73 911 targa with original seals. My top leaks a bit on the sides (drips) in a real heavy downpour. I suspect if the top was rebuilt and new seals put in I would not have a problem. Check out the top repair manual.
HI c911s would you like a copy of the booklet also, to stop the sides leaking
regards mike
Old 06-26-2006, 11:47 AM
i'm just a cook
onlycafe's Avatar
targa is german for leaky.
Old 06-26-2006, 12:08 PM
MBEngineering...if possible I would like to receive a copy of the targa booklet also....pm sent with email.
Thank you
Kirk
Old 06-26-2006, 12:16 PM
thanks Mike, I have the repair manual
normally, I do not drive in the rain; eventually I will get around to replacing all the rubber seals on the car........
Old 06-26-2006, 12:53 PM
HI c911s thats OK, this manual is from the service school/training.
keez i need your snail mail add not your E-mail
regards mike
Old 06-26-2006, 01:16 PM
HI info for all 3 of you is on its way by air mail,
tcarney60, keez, 911Gal
regards mike
Old 06-27-2006, 08:31 AM
Mike, thank you very much. Kirk
Kirk
Old 06-27-2006, 02:16 PM
