How to tell if car is R-12 or R134?
Without having to take my car into the shop, how can I tell if my car has R-12 or has been converted to R-134?
Currently own:
1980 911SC slantnose
1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because)
2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD)
Gone but missed:
1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade)
1984 Jeep CJ-7 (1994 Chevy Blazer)
1987 Chevy Corvette (1996 Mustang Cobra)
1993 Jeep Wrangler (1995 Mustang GT Conv.)
2003 Ford Explorer Sport Trac (1987 BMW M6)
Future: Hopefully not too far off
Ferrari Testarossa (Lamboghini Diablo or Countach)
Detomaso Pantera
Old 06-29-2006, 04:31 PM
never ending projects
niner11's Avatar
What year is your car? Most of the time someone will label the compressor as 134A or you can usually tell by the quick disconect fittings. Should have a red one and a blue one ( the Caps that is).
Shoot us a pic of the fittings and I can tell you if its 134A or not
Also, another way is that instead of being weak, with 134 your A/C will completely suck
Old 06-29-2006, 04:46 PM
so true...
Old 06-29-2006, 04:53 PM
I'm assuming its R-134 since it does completely suck but they car is a 1980 so it should have had R-12 but I dont know if it has been converted.
If it has not shoudl I convet it? From the comments on the R-134 I guess not.
Currently own:
Gone but missed:
Detomaso Pantera
Old 06-29-2006, 04:57 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
R-12 fittings are outside-threaded schraeder valves. R-134 are quick-disconnect.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 06-29-2006, 04:59 PM
ruf-porsche's Avatar
If the PO was a pelican you could have one of those propane isobutane cocktail mixture in there. Do a search and you will find advice on this board how to fabricate an adapter to charge the system with this mixture, or you could have freeze 12 in the system. Good luck finding a shop that will work on the system if it contain something other than R12 or R134a.
Old 06-29-2006, 05:19 PM
Barrpete's Avatar
If you haven't done any upgrades on the AC I would stick R-12. Do a search and you will find lots of info on this topic.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 06-29-2006, 05:20 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Is this because it's a conversion or is it your opinion that R-134a is simply not suitible as a refridgerent? My 93 C2's A/C is R-134 from the factory and works perfectly...
Gary R.
Old 06-29-2006, 05:35 PM
911 A/C systems using R-134a can be set up to chill you to the bone. It ain't rocket engineering but some money is required for more modern parts (there are only few systems that will be helped by the "cures in the can") and it takes effort beyond whining and sweating. The first step is periodic maintenance which many (maybe most) people fail to do.
Old 06-29-2006, 06:21 PM
Barrpete's Avatar
R-134a works fine in systems designed for it. The Problem with early 911 AC systems is that they were woefully lacking in both condensor & evaporator area as well as sufficient air flow across either.
Quite of few people on this board have modified their systems to address these problems and have excellent performance with 134a
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 06-29-2006, 06:22 PM
niner11's Avatar
It is a fact that 134a is not as efficient as r12 so we give up a little performance using it. Your car's front fender condensor is why you have pretty good air with 134a.
The 964's are a giant leap forward in 911 a/c in my opinion but the older cars with too little condensor area and an evaporator in the smugglers box were not that effective using r12 to begin with.
Old 06-29-2006, 06:29 PM
Super_Dave_D's Avatar
Its just awesome the things you can learn on this board. I was wondering what mine had and niner11 naled it for me - Thanks!!
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 06-29-2006, 06:35 PM
"It is a fact that 134a is not as efficient as r12".
If judged solely as refrigerants, not true. In a system optimized for R-134a, R-134a will out perform R-12.
Old 06-29-2006, 06:44 PM
niner11's Avatar
Here we go again. You are right, I can optimize my system by bolting a condensor the size of a pizza box on my roof. Short of that I will praise r12
Old 06-29-2006, 07:16 PM
Me like track days
Craig 930 RS's Avatar
Press the release button, watch the gas escape......if a bunch of Democrats show up threatening to fine you, it's R-134
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-29-2006, 07:35 PM
Refrigeration effect of R12 is 105.7 Joules/gram of refrigerant while R-134a is 134.8 J/g. Coefficient of performance (efficiency) is the same out to three places for the same suction superheat. For a given thermal capacity, the R-134a systems require about 20% more system internal volume due to the refrigerant being effectively less dense. If your 20 plus-year-old condensing system is inadequate with R134a it is likely to be inadequate with R12. Cheers and chills. Jim
Old 06-29-2006, 07:37 PM
niner11's Avatar
I'm sorry, you broke up after Joules/gram......
Old 06-29-2006, 07:45 PM
Although, once upon a time I worked in Arkansas I've forgotten the "redneck" units for refrigeration effect. Best I can do now is a conversion into the good "Christian" units of BTU/lbm.
Old 06-29-2006, 07:51 PM
You could moonlight as a Domino pizza driver with that setup and stay cool. Fastest pizza delivery vehicle.
Old 06-29-2006, 08:49 PM
niner11's Avatar
Jim, I don't want to get too far off topic but I was wondering if you might be able to come up with numbers for some of the other choices we have for refrigerants.
I know there is Freeze 12, HC something, etc. Knowing that there is no holy grail of refrigerants is there anything else out there that makes sense to use.
BTW, I like the idea of delivering pizza in the 911. I could write off an entire Griffiths setup.
Thanks, Chuck
Old 06-30-2006, 12:57 PM
