Electronic Speedometer
I have a 3.0L 1975 carrera.
The PO put an electronic speedometer in the dash, this does not work as I suspect the original was mechanical.
If this is the case can the electronic gauge be enabled to work?
1975 911 3.0 Carrera (964 Lookalike Weekender)
1975 911 2.7 (Project)
1979 Ford RS2000
1980 Mini 1275GT
1998 BMW 320i (Daily driver/Reliable Work Horse)
Old 06-29-2006, 02:43 PM
Insane Dutchman
The electric speedometer works off of a disc on the ring gear assembly which has 8 magnets on it. On the outside of the case is a little dimple which holds a sensor which turns the motion of the magnet into a pulse, 8 per revolution, which in turn makes the speedometer go.
I have an electric speedo in my '75 911S, I was able to put it in when I replaced the transmission. I used a later transmission housing with the dimple in it, fitted the disc and away we went.
While any 8 pulse signal would do the job (you could attach magnets to the axles or wheel hubs, pickup on a stationary local point), I suspect the easier answer is to just get a mechanical speedometer..
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 06-29-2006, 03:17 PM
1974-75 mechanical 91164150229
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-29-2006, 04:36 PM
