Motor not stopping on ignition off
My '87 3.2 911 sometimes runs on after the ignition is turned off.
It has about 120K miles on it and uses absolutlely no oil. I'm about to carry out a standard service (plugs, valve clearances etc) for the first time (my first time not the car's!) and am wondering if there is anything else I should check? |
RETIRED
Puttt, puttt, run on or full engine running with all the gauges and lights dead?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
phut, burp, fart etc. Never for more than 2-3 seconds but that feels like an age when your pride and joy sounds like S**t. Lights etc are shut down by the ignition off.
RETIRED
That's dieseling....could be timing or fuel mixture or a leak in the exhaust.
more info needed
When you say it stays running with ignition off:
1. does it chug along for a few seconds and then die? If so, it is dieseling. 2. does it keep running as if the ignition is on? In that case, your talking about a problem in the ignition switch, which I have had.
77 911, 3.0L |
could be dme relay under your seat - check it...
/Jack |
Chugs along for a few seconds - So sounds like dieseling. Hmm - what do I do?. fueling was recently checked and okay. What else can cause this?
timing and octance on gas?
Some immediate things to check. Do you have a timing gun to check the ignition timing. All the standard books and this forum have instructions on how to do this.
Alson, try using a higher octane gas
77 911, 3.0L |
