-   -   Installing "Carrera" graphics (http://forums.pelicanparts.com/porsche-911-technical-forum/291369-installing-carrera-graphics.html)
Kimos 07-01-2006 06:56 PM
Anyone installed "Carrera" vinyl graphics. obtained a 911t that someone started making into a clone. Have the vinyl coming and wanted to inquire re any problems and or tricks when installing them
vanwyk4257 07-01-2006 07:48 PM
I put some of the old "PORSCHE" decals on my rockers. The best advice I can give you is spray a mist of clean water on the area you're putting the decals on to give you a bit of time to move them around to make sure they're straight. Then you can squeegee the water out with a thin bondo spreader or something similar. I would also put some pieces of masking tape above or below the decal to use as a reference point to make sure they're straight. Good luck.
scottb 07-01-2006 08:01 PM
Do a search on the 'net. There are a bunch of descriptions on how to install the graphics.
Joe Bob 07-01-2006 08:26 PM
http://www.nbdgraphics.com/install.html
From my website....
Super_Dave_D 07-01-2006 10:35 PM
Heres what works best for me when applying decals
Clean the area real good and get all of the wax off and dirt off. You can use 3m-wax remover then straight alcohol.
Make sure your hands are clean - use alcohol
spray a soapy solution (like a cap of dish soap in your spray bottle).
Spray the decal liberally with the solution and your hands and the car when you apply it. The soap solution gives you the ability to slide the decal around so you can get it right. Spray on more solution as needed.
When everything is just right - squeegee our the solution form the middle of the decal out
Or just read Mikez link
911mot 07-02-2006 03:27 AM
I spent ages searching PP and found this excellent graphics/decals thread...
http://forums.pelicanparts.com/showthread.php?threadid=64778&highlight=carrera+si de
Raynald 07-02-2006 06:40 AM
decals
Hello
if you install the graphic on your ducktail I find this information ...
http://forums.pelicanparts.com/uploa...1151847604.jpg
Ray
kilodawg 07-02-2006 09:19 AM
I did this myself a while back the best advice I can give you aside from the typical measure, tape line, lubricate details is to cut the graphics into manageable lengths at strategic locations.
I did the job myself and that approach while appearing radical was key to me getting a perfect application. One piece lengths are just way too hard to work with unless you have a lot of practice and the style of the decal lets you cut it into segments without cutting into the color portion of the decal itself.
htron435 07-03-2006 10:48 AM
Hey Ray, do you have an illustration for the side graphics?
Raynald 07-03-2006 02:27 PM
Hello
I am sorry Jay
No I don't have it and I will install new side graphics...
Ray
89911 07-03-2006 03:04 PM
http://forums.pelicanparts.com/uploa...1151964038.jpg http://forums.pelicanparts.com/uploa...1151964198.jpg
I used these as a guideline after doing some research.
htron435 07-04-2006 08:24 AM
Michael-
I can't resize that photo to read the inches -- is that 2" or 3" from bottom of door?
Also, have you scheduled a summer date to the Glen yet? Noel was there last weekend and loved it. We're gonna try to get there this year sometime if possible.
widgeon13 07-04-2006 08:34 AM
mikez- Do you make the CarreraCS script that was used on the Club Sport or can you make the same script (Carrera 3.2) as the ducktail but in a size appropriate for the side of the car same location as the traditional Carrera script??
A little something different. Thanks
Joe Bob 07-04-2006 08:44 AM
Sure,,,sendme a pic. Email is in my sig.
widgeon13 07-04-2006 09:55 AM
mikez - sent you pm with scan and pic of my car
89911 07-04-2006 10:34 AM
http://forums.pelicanparts.com/uploa...1152034419.jpg
Going with Metro NY at the end of August. Always a great event!
Hope this is a better size.
SgtTurbo 07-04-2006 01:08 PM
http://forums.pelicanparts.com/uploa...1152043628.jpg
