aseem's Avatar
Loctite numbers
My 930 Workshop Manual specifies Loctite #73 to be used on the drive pinion locking nut. I can't find any info on this Loctite number on www.loctite.com. I suspect this product is NLA. Any idea which Loctite I should use for locking nus on the drive and driven shafts of a 930 tranny??
Arnljot
1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband
1989 928GT
1972 BMW 3.0S
Old 07-04-2006, 05:14 AM
wcwv04's Avatar
You can use the Loctite #242 or #262
The #242 is the Blue Removable
The #262 is the Red Permanant
The Red is probably what you want. It is permanant but can be removed after heating to 250F. Don't try to remove with out heat or you will snap the bolts.
Good Luck!!
Craig
78 911SC
Old 07-04-2006, 09:13 AM
Use 272 red loctite, high temp-- no worries--
271 red would be fine as well, its just not the high temp variety.
Old 07-04-2006, 10:19 AM
